Datasheet LT3431 (Analog Devices) - 10
DescriptionHigh Voltage, 3A, 500kHz Step-Down Switching Regulator
Pages / Page28 / 10 — APPLICATIO S I FOR ATIO. Ceramic Output Capacitor. Peak Inductor Current …
File Format / SizePDF / 263 Kb
APPLICATIO S I FOR ATIO. Ceramic Output Capacitor. Peak Inductor Current and Fault Current. EMI
APPLICATIO S I FOR ATIO Ceramic Output Capacitor Peak Inductor Current and Fault Current EMI
LT3431
importance, the subsequent suggestions in Peak Induc- physically larger inductor with the possibility of increased tor and Fault Current and EMI will additionally help in the component height and cost. selection of the inductor value.
Peak-to-peak output ripple voltage is the sum of a triwave An alternative way to further reduce output ripple voltage (created by peak-to-peak ripple current (ILP-P) times ESR) is to reduce the ESR of the output capacitor by using a and a square wave (created by parasitic inductance (ESL) ceramic capacitor. Although this reduction of ESR re- and ripple current slew rate). Capacitive reactance is moves a useful zero in the overall loop response, this zero assumed to be small compared to ESR or ESL. can be replaced by inserting a resistor (RC) in series with dI the VC pin and the compensation capacitor CC. (See V = I ESR - + ESL ( )( ) ( ) RIPPLE LP P Σ Ceramic Capacitors in Applications Information.) dt
where: To ensure that the inductor will not saturate, the peak ESR = equivalent series resistance of the output inductor current should be calculated knowing the maxi- capacitor mum load current. An appropriate inductor should then ESL = equivalent series inductance of the output be chosen. In addition, a decision should be made whether capacitor or not the inductor must withstand continuous fault dI/dt = slew rate of inductor ripple current = V conditions. IN/L Peak-to-peak ripple current (I If maximum load current is 1A, for instance, a 1A inductor LP-P) through the inductor and into the output capacitor is typically chosen to be may not survive a continuous 4A overload condition. Dead between 20% and 40% of the maximum load current. It is shorts will actually be more gentle on the inductor because approximated by: the LT3431 has frequency and current limit foldback. Peak inductor and switch current can be significantly V V – V ( )( ) OUT IN OUT higher than output current, especially with smaller induc- ILP-P = V f L ( )( )( ) tors and lighter loads, so don’t omit this step. Powdered IN iron cores are forgiving because they saturate softly, Example: with V whereas ferrite cores saturate abruptly. Other core mate- IN = 12V, VOUT = 5V, L = 10µH, ESR = 0.080Ω and ESL = 10nH, output ripple voltage can be rials fall somewhere in between. The following formula approximated as follows: assumes continuous mode of operation, but errs only slightly on the high side for discontinuous mode, so it can ( ) be used for all conditions. 5 (12 − ) 5 I = 0.5 A P- P ( ) 8 ( ) ( )( – - ) 12 ( − 10 •10 6)(500•103) = I V V V OUT IN OUT I = I LP P + = I PEAK OUT OUT + 2 ( )2( )( )( ) dI V f L Σ = 12 = IN 106 •1.2 dt − 10 •10 6
EMI
V = 0.5 A ( 8 )(0. ) −9 6 RIPPLE 08 + (10•10 )(10 )(1.2) Decide if the design can tolerate an “open” core geometry = 0.046 + 0.012 = mV 58 like a rod or barrel, which have high magnetic field P- P radiation, or whether it needs a closed core like a toroid to To reduce output ripple voltage further requires an in- prevent EMI problems. This is a tough decision because crease in the inductor value with the trade-off being a the rods or barrels are temptingly cheap and small and sn3431 3431fs 10
