Datasheet LT1676 (Analog Devices)
DescriptionWide Input Range, High Efficiency, Step-Down Switching Regulator
Pages / Page16 / 1 — FEATURES. DESCRIPTIO. Wide Input Range: 7.4V to 60V. Adaptive Switch …
File Format / SizePDF / 149 Kb
FEATURES. DESCRIPTIO. Wide Input Range: 7.4V to 60V. Adaptive Switch Drive Maintains Efficiency at High
Datasheet LT1676 Analog Devices
LT1676 Wide Input Range, High Efficiency, Step-Down Switching Regulator
U FEATURES DESCRIPTIO
The LT®1676 is a wide input range, high efficiency Buck ■ 700mA Peak Switch Current Rating (step-down) switching regulator. The monolithic die in- ■
cludes all oscillator, control and protection circuitry. The
Load Without Pulse Skipping at Light Load
part can accept input voltages as high as 60V and contains ■ True Current Mode Control an output switch rated at 700mA peak current. Current ■ 100kHz Fixed Operating Frequency mode control offers excellent dynamic input supply rejec- ■ Synchronizable to 250kHz tion and short-circuit protection. ■ Low Supply Current in Shutdown: 30µA The LT1676 contains several features to enhance effi- ■ Available in 8-Pin SO and PDIP Packages ciency. The internal control circuitry is normally powered via the VCC pin, thereby minimizing power drawn directly
U
from the V
APPLICATIO S
IN supply (see Applications Information). The action of the LT1676 switch circuitry is also load depen- ■ Automotive DC/DC Converters dent. At medium to high loads, the output switch circuitry ■ Telecom 48V Step-Down Converters maintains high rise time for good efficiency. At light loads, ■ Cellular Phone Battery Charger Accessories rise time is deliberately reduced to avoid pulse skipping ■ IEEE 1394 Step-Down Converters behavior. The available SO-8 package and 100kHz switching fre- quency allow for minimal PC board area requirements. , LTC and LT are registered trademarks of Linear Technology Corporation.
U TYPICAL APPLICATIO
VIN
Efficiency vs VIN and ILOAD
8V TO 50V 5 90 VIN 1 2 SHDN V 80 CC 220µH* 3 5V VSW + 70 + 400mA 39µF 100µF MBR160 36.5k 63V LT1676 10V 1% 60 7 FB 6 8 50 SYNC VC EFFICIENCY (%) 2200pF 40 VIN = 12V 12.1k 1% VIN = 24V GND 22k 100pF 30 VIN = 36V V 4 IN = 48V 20 *65T #30 ON MAGNETICS 1676 F01 1 10 100 1000 MPP #55030 ILOAD (mA) 1676 TA01
Figure 1
1
