Datasheet ADL5569 (Analog Devices) - 8
Description6.5 GHz, Ultrahigh Dynamic Range, Differential Amplifier
Pages / Page23 / 8 — ADL5569. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 3.0. 2.5. 2.0. …
RevisionC
File Format / SizePDF / 750 Kb
ADL5569. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 3.0. 2.5. 2.0. rees). 1.5. Deg. 1.0. B ( L. 0.5. SMA. N (. CHANNE. SE MI. –0.5. A T –1.0. –1.5
ADL5569 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 3.0 2.5 2.0 rees) 1.5 Deg 1.0 B ( L 0.5 SMA N ( CHANNE SE MI –0.5 A T –1.0 –1.5
VS = 5 V, maximum gain, VCOM = VS/2, RS = 100 Ω differential, RL = 100 Ω differential, VOUT = 2 V p-p, frequency = 500 MHz, TA = 25°C, parameters specified for differential input and differential output, and signal spacing = 2 MHz for two-tone measurements, unless otherwise noted.
21 3.0 20 2.5 2.0 19 rees) 1.5 Deg 18 H 1.0 C B ( L 17 T B) 0.5 d SMA 16 N ( 0 AI CHANNE G 15 SE MI –0.5 O A A T –1.0 PH 14 L –1.5 13 –2.0 CHANNE 12 –2.5 11 –3.0 10M 100M 1G 10G
003
10M 100M 1G 6G
006
FREQUENCY (Hz)
15671-
FREQUENCY (Hz)
15671- Figure 3. Gain vs. Frequency (S Parameters Taken with DUT, PCB Not Used in Figure 6. Phase Mismatch (Channel A to Channel B) vs. Frequency Measurement)
20 20 +85°C GAIN = 19dB 18 +25°C 18 –40°C 16 14 16 GAIN = 14dB Bm) d 12 B) B ( 14 d 10 1d N ( GAIN = 10dB P AI G UT 12 8 P UT 6 O GAIN = 6dB 10 4 +80°C 8 2 +25°C –40°C 0 6 10M 100M 1G 10G
004
0 1000 2000 3000 4000 5000 6000
007
FREQUENCY (Hz) FREQUENCY (MHz)
15671- 15671- Figure 4. Gain vs. Frequency over Temperature Figure 7. Output P1dB vs. Frequency over Temperature
0.25 16 0.20 14 B) 0.15 (d 12 B 0.10 L ) CH dB ( 10 0.05 E AT R M IS CHANNE 0 8 O FIGU N M E –0.05 AI A T 6 G L OIS –0.10 N 4 –0.15 CHANNE 2 –0.20 –0.25 0 10M 100M 1G 10G
005
0 1 2 3 4 5 6
008
FREQUENCY (Hz)
15671-
FREQUENCY (GHz)
15671- Figure 5. Gain Mismatch (Channel A to Channel B) vs. Frequency Figure 8. Noise Figure vs. Frequency Rev. A | Page 8 of 23 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Basic Connections Input and Output Interfacing Single-Ended Input to Differential Output Gain Adjustment and Interfacing Effect of Load Capacitance GSPS ADC Interfacing Soldering Information and Recommended Land Pattern Evaluation Board Outline Dimensions Ordering Guide
