Datasheet ADA4945-1 (Analog Devices) - 10
DescriptionHigh-Speed, ±0.3µV/°C Offset Drift, Fully Differential ADC Driver
Pages / Page18 / 10 — ADA4945-1. Preliminary Technical Data. General Performance. Table 7. Full …
RevisionPrC
File Format / SizePDF / 468 Kb
ADA4945-1. Preliminary Technical Data. General Performance. Table 7. Full Power Mode. Low Power Mode. Parameter
ADA4945-1 Preliminary Technical Data General Performance Table 7 Full Power Mode Low Power Mode Parameter
ADA4945-1 Preliminary Technical Data General Performance Table 7. Full Power Mode Low Power Mode Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
CLAMP Clamp Output Voltage Differential −VS − +VS + −VS − +VS + V 0.5 0.5 0.5 0.5 Common mode −VS +VS −VS +VS V Recovery Time TBD TBD ns Input Resistance Resistance between +VCLAMP and 480 480 kΩ −VCLAMP DISABLE (DISABLE PIN) MODE Input Voltage Disabled −VS – DGND + 1 −VS – DGND + 1 V 0.3 0.3 Enabled DGND + +VS + DGND + +VS + V 1.4 0.3 1.4 0.3 Turn Off Time 50% of quiescent current < 10% 1 TBD µs of enabled quiescent current Turn On Time 50% of tO >90% of final VOUT 1 TBD µs DISABLE Pin Bias Current Enabled DISABLE = 5 V 50 50 nA Disabled DISABLE = 0 V 50 50 nA DGND PIN VOLTAGE RANGE –VS +VS – 2.5 –VS +VS – 2.5 V POWER SUPPLY Operating Range 3 10 3 10 V Quiescent Current per Full power mode, MODE = 5 V 4 TBD mA Amplifier, Enabled Low power mode, MODE = 0 V 1.4 TBD mA Disabled Full power mode, MODE = 5 V 30 TBD µA Low power mode, MODE = 0 V 30 TBD µA +PSRR ΔVOS, dm/ΔVS, ΔVS = 1 V p-p −120 −120 dB −PSRR ΔVOS, dm/ΔVS, ΔVS = 1 V p-p −120 −120 dB OPERATING TEMPERATURE −40 +125 −40 +125 °C RANGE Rev. PrA | Page 10 of 18 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Specifications Supply Voltage (VS) = 10 V Positive Input (+DIN) or Negative Input (–DIN) to Differential Output Voltage (VOUT, dm) Performance VOCM to VOUT, cm Performance General Performance VS = 5 V +DIN or –DIN to VOUT, dm Performance VOCM to VOUT, cm Performance General Performance VS = 3 V +DIN or –DIN to VOUT, dm Performance VOCM to VOUT, cm Performance General Performance Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Terminology Outline Dimensions
