Datasheet LTC6363 (Analog Devices) - 7
DescriptionPrecision, Low Power Differential Amplifier/ADC Driver Family
Pages / Page40 / 7 — LTC6363-0.5 Only. The. denotes the specifications which apply over the …
RevisionC
File Format / SizePDF / 703 Kb
LTC6363-0.5 Only. The. denotes the specifications which apply over the full
LTC6363-0.5 Only The denotes the specifications which apply over the full
LTC6363 Family ELECTRICAL CHARACTERISTICS
denotes the specifications which apply over the full operating temperature range, otherwise specifications and typical values are at TA = 25°C. V+ = 10V, V– = 0V, VCM = VOCM = VICM = 5V, VSHDN = open. VS is defined as (V+ – V–). VOUTCM is defined as (V+OUT + V–OUT)/2. VICM is defined as (V+IN + V–IN)/2. VOUTDIFF is defined as (V+OUT – V–OUT). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
ISC Output Short-Circuit Current, Either Output VS = 3V, Output Shorted to 1.5V l 12 25 mA Pin, Sinking VS = 5V, Output Shorted to 2.5V l 13 35 mA VS = 10V, Output Shorted to 5V l 14 40 mA Output Short-Circuit Current, Either Output VS = 3V, Output Shorted to 1.5V l 25 55 mA Pin, Sourcing VS = 5V, Output Shorted to 2.5V l 27 75 mA VS = 10V, Output Shorted to 5V l 30 90 mA f–3dB –3dB Bandwidth 35 MHz SR Slew Rate Differential 18VP-P Output 44 V/µs FPBW (Note 11) Full Power Bandwidth 10VP-P Output 1.4 MHz 18VP-P Output 0.8 MHz HD2/HD3 2nd/3rd order Harmonic Distortion f = 1kHz, VOUT = 10VP-P –125/–122 dBc Single-Ended Input f = 10kHz, VOUT = 10VP-P –108/–111 dBc f = 100kHz, VOUT = 10VP-P –87/–78 dBc tS Settling Time to a 8VP-P Output Step 0.1% 420 ns 0.01% 440 ns 0.0015% (16-Bit) 550 ns 4ppm (18-Bit) 740 ns
LTC6363-1 Only. The
VOSDIFF (Note 7) Differential Offset Voltage VS = 3V 25 125 µV VICM =1.5V l 250 µV VS = 5V 25 125 µV VICM = 2.5V l 250 µV VS = 10V 25 125 µV VICM = 5V l 250 µV ∆VOSDIFF/∆T Differential Offset Voltage Drift VS = 3V l 0.45 1.25 µV/°C (Notes 7, 8) VS = 5V l 0.45 1.25 µV/°C VS = 10V l 0.45 1.25 µV/°C GDIFF Differential Gain VOUT = 16VP-P 1 V/V Differential Gain Error ±0.002 ±0.0045 % l ±0.0075 % Differential Gain Nonlinearity 0.5 ppm Differential Gain Drift vs Temperature (Note 8) l ±0.2 ±0.5 ppm/°C en (Note 7) Differential Input Referred Noise Voltage f = 100kHz, 10.5 nV/√Hz Density (Includes Internal Resistor Noise) envocm Common Mode Noise Voltage Density f = 100kHz 20 nV/√Hz RIN Input Resistance Common Mode 1050 Ω Differential Mode 2100 Ω CIN Input Capacitance Differential Mode 1.5 pF Common Mode 13.5 pF VICMR (Note 9) Input Common Mode Range VS = 3V, VOCM = 1.5V l –1.5 2.1 V VS = 5V,VOCM = 2.5V l –2.5 5.1 V VS = 10V, VOCM = 5V l –5 12.6 V 6363fb For more information www.linear.com/LTC6363 7
