Datasheet LTC6430-15 (Analog Devices) - 6
Description | High Linearity Differential RF/IF Amplifier/ADC Driver |
Pages / Page | 28 / 6 — Typical perForMance characTerisTics TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD … |
File Format / Size | PDF / 1.7 Mb |
Typical perForMance characTerisTics TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD = 100Ω,
LTC6430-15
Typical perForMance characTerisTics TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD = 100Ω, unless otherwise noted (Note 3). Measurements are performed using Test Circuit A, measuring from 50Ω SMA to 50Ω SMA without de-embedding (Note 4). Differential S Parameters Differential Stability Factor K Noise Figure vs Frequency vs Frequency vs Frequency Over Temperature Over Temperature
25 10 8
T
20
CASE = T
9
CASE =
100°C 7 –40°C 15 8 85°C 25°C 10 S11 60°C 6 85°C S21 7 35°C 5 S12 25°C 6 5 0 S22 0°C 5 –20°C 4 –5 –40°C MAG (dB) –10 4 3 –15 3 NOISE FIGURE (dB) 2 –20 2 STABILITY FACTOR K (UNITLESS) –25 1 1 –30 0 0 0 500 1000 1500 2000 2500 3000 0 1000 2000 3000 4000 5000 50 250 450 650 850 1050 1250 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 643015 G01 643015 G02 643015 G03
Differential Reverse Isolation Differential Input Match (S11DD) Differential Gain (S21DD) (S12DD) vs Frequency Over vs Frequency Over Temperature vs Frequency Over Temperature Temperature
0 16 0
TCASE = TCASE =
100°C 100°C –5 85°C 15 –5 85°C 60°C 60°C 35°C 14 –10 35°C –10 25°C 25°C 0°C 0°C –20°C 13
TCASE =
–15 –20°C –40°C 100°C –40°C –15 85°C MAG S11DD (dB) MAG S21DD (dB) 12 60°C MAG S12DD (dB) –20 35°C –20 25°C 11 0°C –25 –20°C –40°C –25 10 –30 0 500 1000 1500 2000 0 500 1000 1500 2000 0 500 1000 1500 2000 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 643015 G04 643015 G05 643015 G06
Differential Output Match (S22DD) Common Mode Gain (S21CC) CM-DM Gain (S21DC) vs Frequency Over Temperature vs Frequency Over Temperature vs Frequency Over Temperature
0 16 0
TCASE =
100°C 15 –5 –5 85°C 14 60°C –10 13 –10 35°C –15 25°C 12 0°C –20 11
T
–15 –20°C
CASE = T
–25
CASE =
–40°C 10 100°C 100°C 85°C –30 85°C MAG S22DD (dB) 9 –20 MAG S21CC (dB) 60°C MAG S21DC (dB) 60°C 8 35°C –35 35°C 25°C 25°C –25 7 0°C –40 0°C 6 –20°C –45 –20°C –40°C –40°C –30 5 –50 0 500 1000 1500 2000 0 500 1000 1500 2000 0 500 1000 1500 2000 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 643015 G07 643015 G08 643015 G09 643015f 6 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation Applications Information Differential S Parameters Typical Applications Package Description Typical Application Related Parts
