Datasheet LTC6417 (Analog Devices) - 3
Description1.6GHz Low Noise High Linearity Differential Buffer/16-Bit ADC Driver with Fast Clamp
Pages / Page32 / 3 — Dc elecTrical characTerisTics. The. denotes the specifications which …
Dc elecTrical characTerisTics. The. denotes the specifications which apply over the full operating
Dc elecTrical characTerisTics The denotes the specifications which apply over the full operating
LTC6417
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. V+ = 5V, GND = 0V, No RLOAD, CLOAD = 6pF. VCM = 1.25V, CLHI = V+, PWRADJ = V+, SHDN = 0V unless otherwise noted. VINCM is defined as (IN+ + IN–)/2. VOUTCM is defined as (OUT+ + OUT–)/2. VINDIFF is defined as (IN+ – IN–). VOUTDIFF is defined as (OUT+ – OUT–). See DC test circuit schematic. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IOUT Output Current Drive (Notes 1, 4) Single-Ended Measurement of OUT+, OUT– l ±100 mA VOS Differential Input Offset Voltage IN+ = IN– = 1.25V, VOS = VOUTDIFF/GDIFF –3.2 –0.1 3.2 mV l –4 4 mV TCVOS Differential Input Offset Voltage Drift l 1 µV/°C VIOCM Common Mode Offset Voltage, Input VOUTCM – VINCM –120 –60 –10 mV to Output l –140 0 mV IVRMIN Input Voltage Range, IN+, IN– Defined by Output Voltage Swing Test l 0.1 V (Minimum) (Single-Ended) IVRMAX Input Voltage Range IN+, IN– Defined by Output Voltage Swing Test l 2.4 V (Maximum) (Single-Ended) IB Input Bias Current, IN+, IN– IN+ = IN– = 1.25V –13 2 13 µA l –18 18 µA RINDIFF Differential Input Resistance VINDIFF = ±1.2V 12 18.5 25 kΩ l 11 27.5 kΩ CINDIFF Differential Input Capacitance 1 pF RINCM Input Common Mode Resistance IN+ = IN– = 0.65V to 1.85V 5.8 9.25 13 kΩ l 5 15 kΩ CMRR Common Mode Rejection Ratio IN+ = IN– = 0.65V to 1.85V, 63 91 dB CMRR = (VOUTDIFF/GDIFF/1.2V) l 60 dB ROUTDIFF Differential Output Resistance 3 Ω eN Input Noise Voltage Density f = 100kHz 1.5 nV/√Hz iN Input Noise Current Density f = 100kHz 4.3 pA/√Hz
Output Common Mode Voltage Control
GCM VCM Pin Common Mode Gain VCM = 0.65V to 1.85V 0.82 0.92 V/V l 0.8 V/V VINCMDEFAULT Default Input Common Mode Voltage VINCM. IN+, IN–, VCM Pin Floating 1.15 1.25 1.35 V l 1.1 1.4 V VOS (VCM – VINCM) Offset Voltage, VCM to VINCM VCM – VINCM, VCM = 1.25V –85 15 115 mV l –90 135 mV VOUTCMDEFAULT Default Output Common Mode Voltage Inputs Floating, VCM Pin Floating 1.1 1.2 1.3 V l 1 1.35 V VOS (VCM – VOUTCM) Offset Voltage, VCM to VOUTCM VCM – VOUTCM, VCM = 1.25V –50 75 200 mV l –45 230 mV VOUTCMMIN Output Common Mode Voltage Range VCM = 0.1V 0.29 0.63 V (Minimum) l 0.65 V VOUTCMMAX Output Common Mode Voltage Range VCM = 2.4V 2 2.25 V (Maximum) l 1.85 V VCMDEFAULT VCM Pin Default Voltage 1.15 1.25 1.35 V l 1.1 1.4 V RVCM VCM Pin Input Resistance VCM = 0.65V to 1.85V 2 2.7 3.4 kΩ l 1.9 3.7 kΩ CVCM VCM Pin Input Capacitance 1 pF IBVCM VCM Pin Bias Current VCM = 1.25V –15 1 15 µA l –27.5 27.5 µA 6417f 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions DC Test Circuit Schematic Block Diagram Applications Information Package Description Typical Application Related Parts
