Datasheet LTC6409 (Analog Devices) - 5
Description10GHz GBW, 1.1nV/√Hz Differential Amplifier/ADC Driver
Pages / Page24 / 5 — ELECTRICAL CHARACTERISTICS Note 7:. Note 9:. Note 8:. Note 10:. Note 11:. …
File Format / SizePDF / 457 Kb
ELECTRICAL CHARACTERISTICS Note 7:. Note 9:. Note 8:. Note 10:. Note 11:. Note 12:. TYPICAL PERFORMANCE CHARACTERISTICS
ELECTRICAL CHARACTERISTICS Note 7: Note 9: Note 8: Note 10: Note 11: Note 12: TYPICAL PERFORMANCE CHARACTERISTICS
LTC6409
Input common mode range is tested by testing at both VICM = 1.25V Effects of Resistor Pair Mismatch in the Applications Information section and at the Electrical Characteristics table limits to verify that the differential of this data sheet). For a better indicator of actual amplifier performance offset (VOSDIFF) and the common mode offset (VOSCM) have not deviated by independent of feedback component matching, refer to the PSRR more than ±1mV and ±2mV respectively from the VICM = 1.25V case. specification. The voltage range for the output common mode range is tested by
Note 9:
Differential power supply rejection (PSRR) is defined as the ratio applying a voltage on the VOCM pin and testing at both VOCM = 1.25V and of the change in supply voltage to the change in differential input referred at the Electrical Characteristics table limits to verify that the common offset voltage. Common mode power supply rejection (PSRRCM) is mode offset (VOSCM) has not deviated by more than ±6mV from the defined as the ratio of the change in supply voltage to the change in the VOCM = 1.25V case. output common mode offset voltage.
Note 8:
Input CMRR is defined as the ratio of the change in the input
Note 10:
Supply voltage range is guaranteed by power supply rejection common mode voltage at the pins +IN or –IN to the change in differential ratio test. input referred offset voltage. Output CMRR is defined as the ratio of
Note 11:
Extended operation with the output shorted may cause the the change in the voltage at the VOCM pin to the change in differential junction temperature to exceed the 150°C limit. input referred offset voltage. This specification is strongly dependent on
Note 12:
Refer to Relationship Between Different Linearity Metrics in the feedback ratio matching between the two outputs and their respective Applications Information section of this data sheet for information on how inputs and it is difficult to measure actual amplifier performance (See to calculate an equivalent OIP3 from IMD3 measurements.
TYPICAL PERFORMANCE CHARACTERISTICS Differential Input Offset Voltage Differential Input Offset Voltage Common Mode Offset Voltage vs Temperature vs Input Common Mode Voltage vs Temperature
1.5 2.0 2.5 VS = 5V VOCM = 1.25V 1.5 RI = RF = 150Ω 2.0 1.0 0.1% FEEDBACK NETWORK RESISTORS REPRESENTATIVE UNIT TAGE (mV) V (mV) (mV) 1.0 S = 5V 1.5 V OS OS OCM = VICM = 1.25V RI = RF = 150Ω 0.5 V FIVE REPRESENTATIVE UNITS S = 5V 0.5 1.0 VOCM = VICM = 1.25V RI = RF = 150Ω FIVE REPRESENTATIVE UNITS 0 0.5 T DIFFERENTIAL V 0 DIFFERENTIAL V A = 85°C TA = 70°C –0.5 TA = 25°C 0 TA = 0°C COMMON MODE OFFSET VOL TA = –40°C –0.5 –1.0 –0.5 –50 –25 0 25 50 75 100 125 0 0.5 1 1.5 2 2.5 3 3.5 4 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) INPUT COMMON MODE VOLTAGE (V) TEMPERATURE (°C) 6409 G01 6409 G02 6409 G03
Shutdown Supply Current vs Supply Current vs Supply Voltage Supply Current vs SHDN Voltage Supply Voltage
60 60 140 VSHDN = OPEN V T 55 S = 5V 55 A = 125°C TA = 85°C 50 50 120 TA = 70°C 45 45 TA = 25°C 100 TA = 0°C 40 40 TA = –40°C 35 35 Y CURRENT (µA) 80 Y CURRENT (mA) 30 Y CURRENT (mA) 30 25 25 60 20 TA = 125°C 20 TA = 125°C AL SUPPL T T 40 15 A = 85°C AL SUPPL A = 85°C T 15 A = 70°C TA = 70°C TOT 10 TA = 25°C TOT 10 TA = 25°C SHUTDOWN SUPPL 20 5 TA = 0°C TA = 0°C T 5 A = –40°C TA = –40°C VSHDN = V– 0 0 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 SUPPLY VOLTAGE (V) SHDN VOLTAGE (V) SUPPLY VOLTAGE (V) 6409 G04 6409 G05 6409 G06 6409fb For more information www.linear.com/LTC6409 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Applications Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics Pin Configuration Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Applications Related Parts
