Datasheet LTC6400-8 (Analog Devices) - 3
Description2.2GHz Low Noise, Low Distortion Differential ADC Driver for DC-300MHz
Pages / Page16 / 3 — DC ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which …
File Format / SizePDF / 224 Kb
DC ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
DC ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC6400-8
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, +IN = –IN = VOCM = 1.25V, ENABLE = 0V, No RL unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Input/Output Characteristic
GDIFF Gain VIN = ±400mV Differential l 7.5 8 8.5 dB TCGAIN Gain Temperature Drift VIN = ±400mV Differential l –0.13 mdB/°C VSWINGMIN Output Swing Low Each Output, VIN = ±1.6V Differential l 74 170 mV VSWINGMAX Output Swing High Each Output, VIN = ±1.6V Differential l 2.3 2.48 V VOUTDIFFMAX Maximum Differential Output Swing 1dB Compressed l 4.8 VP-P IOUT Output Current Drive VOUT > 2VP-P,DIFF l 20 mA VOS Input Offset Voltage Differential l –5 5 mV TCVOS Input Offset Voltage Drift Differential l 2 μV/°C IVRMIN Input Common Mode Voltage Range, MIN 1 V IVRMAX Input Common Mode Voltage Range, MAX 1.8 V RINDIFF Input Resistance (+IN, –IN) Differential l 340 400 460 Ω CINDIFF Input Capacitance (+IN, –IN) Differential, Includes Parasitic 1 pF ROUTDIFF Output Resistance (+OUT, –OUT) Differential l 18 25 32 Ω ROUTFDIFF Filtered Output Resistance (+OUTF, –OUTF) Differential l 85 100 115 Ω COUTFDIFF Filtered Output Capacitance (+OUTF, –OUTF) Differential, Includes Parasitic 2.7 pF CMRR Common Mode Rejection Ratio Input Common Mode Voltage 1.1V~1.7V l 39 55 dB
Output Common Mode Voltage Control
GCM Common Mode Gain VOCM = 1V to 1.6V 1 V/V VOCMMIN Output Common Mode Range, MIN 1 V l 1.1 V VOCMMAX Output Common Mode Range, MAX 1.6 V l 1.5 V VOSCM Common Mode Offset Voltage VOCM = 1.1V to 1.5V l –15 15 mV TCVOSCM Common Mode Offset Voltage Drift l 6 μV/°C IVOCM VOCM Input Current l 4.5 15 μA
ENABLE Pin
VIL ENABLE Input Low Voltage l 0.8 V VIH ENABLE Input High Voltage l 2.4 V IIL ENABLE Input Low Current ENABLE = 0.8V l 0.5 μA IIH ENABLE Input High Current ENABLE = 2.4V l 1.3 4 μA
Power Supply
VS Operating Supply Range l 2.85 3 3.5 V IS Supply Current ENABLE = 0.8V, Input and Output Floating l 70 85 95 mA ISHDN Shutdown Supply Current ENABLE = 2.4V, Input and Output Floating l 0.9 3 mA PSRR Power Supply Rejection Ratio V+ = 2.85V to 3.5V l 50 68 dB (Differential Outputs) 64008f 3
