Datasheet LTC6401-14 (Analog Devices) - 7
Description | 2GHz Low Noise, Low Distortion Differential ADC Driver for DC-140MHz |
Pages / Page | 16 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Third Order Intermodulation. … |
File Format / Size | PDF / 225 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Third Order Intermodulation. Distortion vs Frequency. Harmonic Distortion vs Frequency
LTC6401-14
TYPICAL PERFORMANCE CHARACTERISTICS Third Order Intermodulation Third Order Intermodulation Distortion vs Frequency Harmonic Distortion vs Frequency Distortion vs Frequency
–40 –40 –40 DIFFERENTIAL INPUT SINGLE-ENDED INPUT SINGLE-ENDED INPUT VOUT = 2VP-P COMPOSITE V V OUT = 2VP-P OUT = 2VP-P COMPOSITE –50 –50 –50 –60 –60 –60 200Ω R 200Ω R L L –70 –70 –70 –80 –80 –80 NO R NO R L L –90 –90 –90 THIRD ORDER IMD (dBc) HD2 NO R THIRD ORDER IMD (dBc) L HARMONIC DISTORTION (dBc) HD2 200Ω R –100 –100 L –100 HD3 NO RL HD3 200Ω RL –110 –110 –110 0 20 40 60 80 100 120 140 160 180 200 0 20 40 60 80 100 120 140 160 180 200 0 20 40 60 80 100 120 140 160 180 200 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 640114 G13 640114 G14 640114 G15
Equivalent Output 1dB Equivalent Output Third Order Compression Point vs Frequency Intercept Point vs Frequency
20 60 DIFFERENTIAL INPUT RL = 375Ω TEST CIRCUIT A (NOTE 7) 50 NO R 19 L 40 18 200Ω RL 30 17 OUTPUT IP3 (dBm) 20 16 10 DIFFERENTIAL INPUT OUTPUT 1dB COMPRESSION POINT (dBm) (NOTE 7) 15 0 0 20 40 60 80 100 120 140 160 180 200 0 20 40 60 80 100 120 140 160 180 200 FREQUENCY (MHz) FREQUENCY (MHz) 640114 G16 640114 G17
Turn-On Time Turn-Off Time
3.5 70 3.5 70 RL = 87.5Ω PER OUTPUT 3.0 60 3.0 60 ICC 2.5 50 2.5 50 2.0 40 I 2.0 40 CC ICC (mA) +OUT (mA) 1.5 +OUT 30 1.5 30 VOLTAGE (V) 1.0 20 VOLTAGE (V) 1.0 –OUT 20 0.5 –OUT 10 0.5 10 0 0 0 0 ENABLE R ENABLE ICC L = 87.5Ω PER OUTPUT –0.5 –10 –0.5 –10 –100 0 100 200 300 400 –100 0 100 200 300 400 TIME (ns) TIME (ns) 640114 G18 640114 G19 640114f 7
