Datasheet LT1994 (Analog Devices) - 4
DescriptionLow Noise, Low Distortion Fully Differential Input/Output Amplifier/Driver
Pages / Page20 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 232 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LT1994
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, VCM = VOCM = VICM = mid-supply, VSHDN = OPEN, RI = RF = 499
Ω
, RL = 800
Ω
to a mid-supply voltage (See Figure 1) unless otherwise noted. VS is defi ned (V+ – V–). VOUTCM is defi ned as (V + + + + OUT + VOUT )/2. VICM is defi ned as (VIN + VIN )/2. VOUTDIFF is defi ned as (VOUT – VOUT ). VINDIFF is defi ned as (VIN – VIN ). C/I GRADES H/MP GRADES SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
ΔVOSCM/ΔT Common Mode Offset Voltage Drift VS = 2.375V, VICM = VS/4 5 5 μV/°C VS = 3V 5 5 μV/°C VS = 5V 5 5 μV/°C VS = ±5V 5 5 μV/°C VOUTCMR Output Signal Common Mode Range VS = 3V, ±5V l V– + V+ V– + V+ V (Note 7) (Voltage Range for the VOCM Pin) 1.1 – 0.8 1.1 – 0.8 RINVOCM Input Resistance, VOCM Pin l 30 40 60 30 40 60 kΩ VMID Voltage at the VOCM Pin VS = 5V l 2.45 2.5 2.55 2.45 2.5 2.55 V VOUT Output Voltage, High, Either Output Pin VS = 3V, No Load l 70 140 70 140 mV (Note 10) VS = 3V, RL = 800Ω l 90 175 90 175 mV VS = 3V, RL = 100Ω l 200 400 200 400 mV VS = ±5V, No Load l 150 325 150 325 mV VS = ±5V, RL = 800Ω l 200 450 200 450 mV VS = ±5V, RL = 100Ω l 900 2400 900 2400 mV Output Voltage, Low, Either Output Pin VS = 3V, No Load l 30 70 30 70 mV (Note 10) VS = 3V, RL = 800Ω l 50 90 50 90 mV VS = 3V, RL = 100Ω l 125 250 125 250 mV VS = ±5V, No Load l 80 180 80 180 mV VS = ±5V, RL = 800Ω l 125 250 125 250 mV VS = ±5V, RL = 100Ω l 900 2400 900 2400 mV ISC Output Short-Circuit Current, Either V l S = 2.375V, RL = 10Ω ±25 ±35 ±10 ±35 mA Output Pin (Note 11) V l S = 3V, RL = 10Ω ±30 ±40 ±15 ±40 mA V l S = 5V, RL = 10Ω ±40 ±65 ±40 ±65 mA V l S = ±5V, VCM = 0V, RL = 10Ω ±45 ±85 ±45 ±85 mA SR Slew Rate V + – l S = 5V, ΔVOUT = –ΔVOUT = 1V 50 65 85 50 65 85 V/μS V l S = ±5V, VCM = 0V, 50 65 85 50 65 85 V/μS ΔV + – OUT = –ΔVOUT = 1.8V GBW Gain-Bandwidth Product VS = 3V, TA = 25°C l 58 70 58 70 MHz (fTEST = 1MHz) VS = ±5V, VCM = 0V, TA = 25°C l 58 70 58 70 MHz Distortion VS = 3V, RL = 800Ω, fIN = 1MHz, V + – OUT – VOUT = 2VP-P Differential Input 2nd Harmonic –99 –99 dBc 3rd Harmonic –96 –96 dBc Single-Ended Input 2nd Harmonic –94 –94 dBc 3rd Harmonic –108 –108 dBc tS Settling Time VS = 3V, 0.01%, 2V Step 120 120 ns VS = 3V, 0.1%, 2V Step 90 90 ns AVOL Large-Signal Voltage Gain VS = 3V 100 100 dB VS Supply Voltage Range l 2.375 12.6 2.375 12.6 V IS Supply Current VS = 3V l 13.3 18.5 13.3 20.0 mA VS = 5V l 13.9 19.5 13.9 20.5 mA VS = ±5V l 14.8 20.5 14.8 21.5 mA ISHDN Supply Current in Shutdown VS = 3V l 0.225 0.8 0.225 0.8 mA VS = 5V l 0.375 1.75 0.375 1.75 mA VS = ±5V l 0.7 2.5 0.7 2.5 mA 1994fb 4
