Datasheet AD8369 (Analog Devices) - 6
Description600 MHz, 45 dB Digitally Controlled Variable Gain Amplifier
Pages / Page24 / 6 — AD8369. PIN CONFIGURATION. INLO. 16 INHI. COMM. 15 COMM. BIT0. 14 PWUP. …
File Format / SizePDF / 671 Kb
AD8369. PIN CONFIGURATION. INLO. 16 INHI. COMM. 15 COMM. BIT0. 14 PWUP. TOP VIEW. BIT1. 13 VPOS. (Not To Scale). BIT2. 12 SENB. BIT3. 11 FILT. DENB
AD8369 PIN CONFIGURATION INLO 16 INHI COMM 15 COMM BIT0 14 PWUP TOP VIEW BIT1 13 VPOS (Not To Scale) BIT2 12 SENB BIT3 11 FILT DENB
AD8369 PIN CONFIGURATION INLO 1 16 INHI COMM 2 15 COMM BIT0 3 AD8369 14 PWUP TOP VIEW BIT1 4 13 VPOS (Not To Scale) BIT2 5 12 SENB BIT3 6 11 FILT DENB 7 10 CMDC OPLO 8 9 OPHI PIN FUNCTION DESCRIPTIONS Pin No. Mnemonic Function
1 INLO Balanced Differential Input. Internally biased, should be ac-coupled. 2 COMM Device Common. Connect to low impedance ground. 3 BIT0 Gain Selection Least Significant Bit. Used as DATA input signal when in serial mode of operation. 4 BIT1 Gain Selection Control Bit. Used as CLOCK input pin when in serial mode of operation. 5 BIT2 Gain Selection Control Bit. Inactive when in serial mode of operation. 6 BIT3 Gain Selection Most Significant Bit. Inactive when in serial mode of operation. 7 DENB Data Enable Pin. Writes data to register. See Timing Specifications for details. 8 OPLO Balanced Differential Output. Biased to midsupply, should be ac-coupled. 9 OPHI Balanced Differential Output. Biased to midsupply, should be ac-coupled. 10 CMDC Common-Mode Decoupling Pin. Connect bypass capacitor to ground for additional common-mode supply decoupling beyond the existing internal decoupling. 11 FILT High-Pass Filter Connection. Used to set high-pass corner frequency. 12 SENB Serial or Parallel Interface Select. Connect SENB to VPOS for serial operation. Connect SENB to COMM for parallel operation. 13 VPOS Positive Supply Voltage, VS = +3 V to +5.5 V. 14 PWUP Power-Up Pin. Connect PWUP to VPOS to power up the device. Connect PWUP to COMM to power-down. 15 COMM Device Common. Connect to a low impedance ground. 16 INHI Balanced Differential Input. Internally biased, should be ac-coupled. –6– REV. A Document Outline Features Applications Functional Block Diagram Product Description Specifications Timing Specifications Absolute Maximum Ratings Pin Configuration Typical Performance Characteristics Theroy of Operation Input Attentuator and Output 3 dB Step Fixed Gain Amplifier Input and Output Interfaces Noise and Distortion Offset Control Loop Digital Control Basic Connections Input-Output Interface Reducing Gain Sensitivity to Input and Output Impedance Variation Operation from a Single-Sided Source Interfacing to an ADC PCB Layout Considerations Evaluation Board Evaluation Board Software Appendix Characterization Equipment Definitions of Selected Parameters Composite Waveform Assumption Outline Dimensions Ordering Guide Revision History
