Datasheet LTC6360 (Analog Devices) - 6
Description | Very Low Noise Single-Ended SAR ADC Driver with True Zero Output |
Pages / Page | 24 / 6 — Typical perForMance characTerisTics. TA = 25°C, VCC = VDD = 5V, V+IN = … |
File Format / Size | PDF / 531 Kb |
Typical perForMance characTerisTics. TA = 25°C, VCC = VDD = 5V, V+IN = 2V, VSHDN = 5V,
LTC6360
Typical perForMance characTerisTics TA = 25°C, VCC = VDD = 5V, V+IN = 2V, VSHDN = 5V, see Figure 1 for circuit configuration. Total Supply Current vs Total Supply Current in Shutdown Input Bias Current vs Temperature Temperature vs Temperature
–6 16 300 VSHDN = 5V VSHDN = 0V –8 –10 V 15 250 +IN = 4V –12 14 200 –14 –16 V+IN = 2V SUPPLY CURRENT (mA) SUPPLY CURRENT (µA) INPUT BIAS CURRENT (µA) 13 150 –18 –20 12 100 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 6360 G07 6360 G08 6360 G09
Total Supply Currents vs Supply Total Supply Currents vs Turn-On and Turn-Off Transient Voltage SHDN Voltage Response
20 18 6 T 18 A = 125°C T V A = 25°C 16 SHDN 5 16 TA = –40°C 14 14 4 12 12 10 3 VOUT 10 8 8 2 VOLTAGE (V) 6 6 SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) 1 4 4 TA = 125°C 0 2 2 TA = 25°C VCPO TA = –40°C 0 0 –1 0 1 2 3 4 5 0 1 2 3 4 5 5µs/DIV 6360 G12 SUPPLY VOLTAGE (V) SHDN PIN VOLTAGE (V) 6360 G10 6360 G11
Output Settling Time vs Input Voltage Noise vs Frequency 0.1Hz to 10Hz Voltage Noise Output Step
100 2000 120 1500 100 ) Hz 1000 80 TO 1mV 500 10 0 60 –500 40 VOLTAGE NOISE (nV) SETTLING TIME (ns) TO 10mV VOLTAGE NOISE (nV/√ –1000 20 –1500 1 –2000 0 10 100 1k 10k 100k 1M 10M 100M 1G TIME (1s/DIV) 6360 G14 –4 –3 –2 –1 0 1 2 3 4 FREQUENCY (Hz) OUTPUT STEP (V) 6360 G13 6360 G15 6360f 6 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order InFormation Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit Operation Applications Information Package Description Typical Application Related Parts
