Datasheet LT6350 (Analog Devices) - 5
DescriptionLow Noise Single-Ended to Differential Converter/ADC Driver
Pages / Page28 / 5 — elecTrical characTerisTics. The. denotes specifications that apply over …
File Format / SizePDF / 891 Kb
elecTrical characTerisTics. The. denotes specifications that apply over the full specified temperature range,
elecTrical characTerisTics The denotes specifications that apply over the full specified temperature range,
LT6350
denotes specifications that apply over the full specified temperature range, otherwise specifications are at TA = 25°C. Unless noted otherwise, V+ = 5V, V– = 0V, V+IN1 = V2 = Mid-Supply, VSHDN = V+, RL = OPEN, RF = SHORT, RG = OPEN. VS is defined as (V+ – V–). VOUTCM is defined as (VOUT1 + VOUT2)/2. VOUTDIFF is defined as (VOUT1 – VOUT2). See Figure 1. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
FPBW Full-Power Bandwidth (Note 11) VOUTDIFF = 8VP-P 1.6 MHz CL Capacitive Load Drive, 20% Overshoot No Series Output Resistors 56 pF SR Differential Slew Rate OUT1 Rising (OUT2 Falling) 48 V/µs OUT1 Falling (OUT2 Rising) 41 V/µs 10kHz Distortion VS = 5V, VOUTDIFF = 4VP-P, RL = 2kΩ HD2 2nd Harmonic –115 dBc HD3 3rd Harmonic –115 dBc 100kHz Distortion VS = 5V, VOUTDIFF = 4VP-P, RL = 2kΩ HD2 2nd Harmonic –102 dBc HD3 3rd Harmonic –97 dBc 1MHz Distortion VS = 5V, VOUTDIFF = 4VP-P, RL = 2kΩ HD2 2nd Harmonic –86 dBc HD3 3rd Harmonic –75 dBc tS Settling Time to a 4V Input Step 0.1% 200 ns 0.01% 240 ns 0.0015% (±1LSB, 16-Bit, Falling Edge) 350 ns tOVDR Overdrive Recovery Time +IN1 to V– and V+ 200 ns tON Turn-On Time VSHDN = 0V to 5V 400 ns tOFF Turn-Off Time VSHDN = 5V to 0V 400 ns
Note 1:
Note 6:
VOS2 is measured as the total output common mode voltage offset may cause permanent damage to the device. Exposure to any Absolute (error between output common mode and voltage at V2). VOS2 includes Maximum Rating condition for extended periods may affect device the combined effects of op amp 2’s voltage offset, IB, IOS and mismatch reliability and lifetime. between on-chip resistors and the 499Ω external resistor, R1 (See Figure 1).
Note 2:
Inputs are protected by diodes to each supply. Additionallly,
Note 7:
Supply voltage range is guaranteed by the power supply rejection op amp inputs +IN1, –IN1 and +IN2 are protected by back-to-back diodes ratio test. across the op amp inputs. If inputs are taken beyond the supplies or if
Note 8:
Output balance is calculated from gain error and gain as: either op amp’s differential input voltage exceeds 0.7V, the input current must be limited to less than 20mA. GAIN BAL =
Note 3:
A heat sink may be required to keep the junction temperature GAINERR below the absolute maximum rating when the output is shorted indefinitely.
Note 9:
DC linearity is measured by measuring the differential output for
Note 4:
The LT6350C/LT6350I are guaranteed functional over the each input in the set V+IN1 = 0.5V, 2.5V, 4.5V, and calculating the maximum temperature range of –40°C to 85°C. The LT6350H is guaranteed deviation from the least squares best fit straight line generated from the functional over the temperature range of –40°C to 125°C. three data points.
Note 5:
The LT6350C is guaranteed to meet specified performance from
Note 10:
Output voltage swings are measured between the output and 0°C to 70°C. The LT6350C is designed, characterized and expected to power supply rails. meet specified performance from –40°C to 85°C, but is not tested or
Note 11:
Full- power bandwidth is calculated from the slew rate. QA sampled at these temperatures. The LT6350I is guaranteed to meet FPBW = SR/2�V specified performance from –40°C to 85°C. The LT6350H is guaranteed to P. meet specified performance from –40°C to 125°C. 6350fc For more information www.linear.com/LT6350 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration order information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram DC Test Circuit Operation Applications Information Typical Application Package Description Revision History Typical Application Related Parts
