Datasheet AD8232 (Analog Devices) - 3
DescriptionSingle-Lead, Heart Rate Monitor Front End
Pages / Page28 / 3 — Data Sheet. AD8232. SPECIFICATIONS. Table 1. Parameter. Symbol. Test …
RevisionC
File Format / SizePDF / 716 Kb
Data Sheet. AD8232. SPECIFICATIONS. Table 1. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD8232 SPECIFICATIONS Table 1 Parameter Symbol Test Conditions/Comments Min Typ Max Unit
link to page 4 link to page 4
VS = 3 V, VREF = 1.5 V, VCM = 1.5 V, TA = 25°C, FR=low, SDN=high, AC/DC = low, unless otherwise noted.
Table 1. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
INSTRUMENTATION AMPLIFIER Common-Mode Rejection Ratio, CMRR VCM = 0.35 V to 2.85 V, VDIFF = 0 V 80 86 dB DC to 60 Hz VCM = 0.35 V to 2.85 V, VDIFF = ±0.3 V 80 dB Power Supply Rejection Ratio PSRR VS = 2.0 V to 3.5 V 76 90 dB Offset Voltage (RTI) VOS Instrumentation Amplifier Inputs 3 8 mV DC Blocking Input1 5 50 µV Average Offset Drift Instrumentation Amplifier Inputs 10 µV/°C DC Blocking Input1 0.05 µV/°C Input Bias Current IB 50 200 pA TA = 0°C to 70°C 1 nA Input Offset Current IOS 25 100 pA TA = 0°C to 70°C 1 nA Input Impedance Differential 10||7.5 GΩ||pF Common Mode 5||15 GΩ||pF Input Voltage Noise (RTI) Spectral Noise Density f = 1 kHz 100 nV/√Hz Peak-to-Peak Voltage Noise f = 0.1 Hz to 10 Hz 12 µV p-p f = 0.5 Hz to 40 Hz 14 µV p-p Input Voltage Range TA = 0°C to 70°C 0.2 +VS V DC Differential Input Range VDIFF −300 +300 mV Output Output Swing RL = 50 kΩ 0.1 +VS − 0.1 V Short-Circuit Current IOUT 6.3 mA Gain AV 100 V/V Gain Error VDIFF = 0 V 0.4 % VDIFF = −300 mV to +300 mV 1 3.5 % Average Gain Drift TA = 0°C to 70°C 12 ppm/°C Bandwidth BW 2 kHz RFI Filter Cutoff (Each Input) 1 MHz OPERATIONAL AMPLIFIER (A1) Offset Voltage VOS 1 5 mV Average TC TA = 0°C to 70°C 5 µV/°C Input Bias Current IB 100 pA TA = 0°C to 70°C 1 nA Input Offset Current IOS 100 pA TA = 0°C to 70°C 1 nA Input Voltage Range 0.1 +VS − 0.1 V Common-Mode Rejection Ratio CMRR VCM = 0.5 V to 2.5 V 100 dB Power Supply Rejection Ratio PSRR 100 dB Large Signal Voltage Gain AVO 110 dB Output Voltage Range RL = 50 kΩ 0.1 +VS − 0.1 V Short-Circuit Current Limit IOUT 12 mA Gain Bandwidth Product GBP 100 kHz Slew Rate SR 0.02 V/µs Voltage Noise Density (RTI) en f = 1 kHz 60 nV/√Hz Peak-to-Peak Voltage Noise (RTI) en p-p f = 0.1 Hz to 10 Hz 6 µV p-p f = 0.5 Hz to 40 Hz 8 µV p-p Rev. C | Page 3 of 28 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Instrumentation Amplifier Performance Curves Operational Amplifier Performance Curves Right Leg Drive (RLD) Amplifier Performance Curves Reference Buffer Performance Curves System Performance Curves Theory of Operation Architecture Overview Instrumentation Amplifier Operational Amplifier Right Leg Drive Amplifier Reference Buffer Fast Restore Circuit Leads Off Detection DC Leads Off Detection AC Leads Off Detection Standby Operation Input Protection Radio Frequency Interference (RFI) Power Supply Regulation and Bypassing Input Referred Offsets Layout Recommendations Applications Information Eliminating Electrode Offsets High-Pass Filtering Two-Pole High-Pass Filter Additional High-Pass Filtering Options Low-Pass Filtering and Gain Driving Analog-to-Digital Converters Driven Electrode Application Circuits Heart Rate Measurement Next to the Heart Exercise Application: Heart Rate Measured at the Hands Cardiac Monitor Configuration Portable Cardiac Monitor with Elimination of Motion Artifacts Packaging and Ordering Information Outline Dimensions Ordering Guide
