Datasheet LTC6915 (Analog Devices) - 4
DescriptionZero Drift, Precision Instrumentation Amplifier with Digitally Programmable Gain
Pages / Page18 / 4 — elecTrical characTerisTics. The. denotes the specifications which apply …
File Format / SizePDF / 297 Kb
elecTrical characTerisTics. The. denotes the specifications which apply over the full operating
elecTrical characTerisTics The denotes the specifications which apply over the full operating
LTC6915
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C.
VOS Input Offset Voltage (Note 3) VCM = 200mV –3 ±10 µV Average Input Offset Drift (Note 3) TA = –40°C to 85°C l ±50 nV/°C TA = 85°C to 125°C ±100 nV/°C Average Input Bias Current (Note 4) VCM = 1.2V l 5 10 nA IOS Average Input Offset Current (Note 4) VCM = 1.2V l 1.5 3 nA CMRR Common Mode Rejection Ratio AV = 1024, VCM = 0V to 5V, LTC6915C l 105 125 dB AV = 1024, VCM = 0.1V to 4.9V, LTC6915I l 105 125 dB AV = 1024, VCM = 0V to 5V, LTC6915I l 95 125 dB AV = 1024, VCM = 0.1V to 4.9V, LTC6915H l 100 dB AV = 1024, VCM = 0V to 4.97V, LTC6915H l 85 dB PSRR Power Supply Rejection Ratio (Note 5) VS = 2.7V to 6V l 110 116 dB Output Voltage Swing High Sourcing 200µA l 4.95 4.99 V Sourcing 2mA l 4.80 4.93 V Output Voltage Swing Low Sinking 200µA l 17 50 mV Sinking 2mA l 120 300 mV
V+ = 5V, V– = 0V, VREF = 200mV
Supply Current, Parallel Mode No Load at OUT, VCM = 200mV l 0.95 1.48 mA Supply Current, Serial Mode (Note 6) No Load at OUT, Capacitive Load at l 1.4 2 mA DOUT (CL) = 15pF, Continuous CLK Frequency = 4MHz, CS = LOW, Gain Control Code = 0001 Supply Current, Shutdown VSHDN = 4.5V (Hardware Shutdown) l 2 10 µA VSHDN = 1V, Gain Control Code = 0000 l 135 200 µA (Software Shutdown) SHDN Input High l 4.5 V SHDN Input Low l 1 V SHDN and HOLD_THRU Input Current (Note 2) l 5 µA Internal Op Amp Gain Bandwidth 200 kHz Slew Rate 0.2 V/µs Internal Sampling Frequency 3 kHz
V+ = 5V, V– = –5V, VREF = 0V
Gain Error (Note 2) AV = 1 (RL = 10k) l –0.075 0 0.075 % Gain Error (Note 2) AV = 2 to 32 (RL = 10k) l –0.5 0 0.5 % Gain Error (Note 2) AV = 64 to 1024 (RL = 10k) l –0.6 –0.1 0.6 % Gain Error (Note 2) AV = 2048, 4096 (RL = 10k) l –1 –0.2 1 % Gain Nonlinearity AV = 1 l 3 15 ppm VOS Input Offset Voltage (Note 3) VCM = 0mV 5 ±20 µV Average Input Offset Drift (Note 3) TA = –40°C to 85°C l ±50 nV/°C TA = 85°C to 125°C l ±100 nV/°C IOS Average Input Bias Current (Note 4) VCM = 1V l 4 10 nA Average Input Offset Current (Note 4) VCM = 1V l 1.5 3 nA 6915fb 4 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagrams Timing Diagram Operation Typical Application Package Description Revision History Typical Application Related Parts
