Datasheet LTC6800 (Analog Devices) - 4
DescriptionRail-to-Rail, Input and Output, Instrumentation Amplifier
Pages / Page14 / 4 — Note 3:. Note 6:. Note 4:. Note 5:. Note 7:. Input Offset Voltage vs …
Note 3:. Note 6:. Note 4:. Note 5:. Note 7:. Input Offset Voltage vs Input. Common Mode Voltage. Common Mode Voltage,
Note 3: Note 6: Note 4: Note 5: Note 7: Input Offset Voltage vs Input Common Mode Voltage Common Mode Voltage,
LTC6800 elecTrical characTerisTics
Note 3:
If the total source resistance is less than 10k, no DC errors result
Note 6:
The power supply rejection ratio (PSRR) measurement accuracy from the input bias currents or the mismatch of the input bias currents or depends on the proximity of the power supply bypass capacitor to the the mismatch of the resistances connected to –IN and +IN. device under test. Because of this, the PSRR is 100% tested to relaxed
Note 4:
The CMRR with a voltage gain, A limits at final test. However, their values are guaranteed by design to meet V, larger than 10 is 120dB (typ).
Note 5:
At temperatures above 70°C, the common mode rejection ratio the data sheet limits. lowers when the common mode input voltage is within 100mV of the
Note 7:
The LTC6800H is guaranteed functional over the operating supply rails. temperature range of –40°C to 125°C. Specifications over the –40°C to 125°C range (denoted by l) are assured by design and characterization but are not tested or QA sampled at these temperatures. Typical perForMance characTerisTics
Input Offset Voltage vs Input Input Offset Voltage vs Input Input Offset Voltage vs Input Common Mode Voltage Common Mode Voltage Common Mode Voltage
15 15 20 VS = 3V VS = 5V VS = 3V VREF = 0V VREF = 0V 15 VREF = 0V 10 TA = 25°C 10 TA = 25°C G = 10 10 G = 1000 5 5 5 0 0 0 G = 1000 T G = 100 A = 70°C G = 100 –5 –5 –5 TA = 25°C G = 10 –10 INPUT OFFSET VOLTAGE (µV) INPUT OFFSET VOLTAGE (µV) G = 10 G = 1 INPUT OFFSET VOLTAGE (µV) –10 –10 TA = –55°C –15 G = 1 –15 –15 –20 0 0.5 1.0 1.5 2.0 2.5 3.0 0 1 2 3 4 5 0 0.5 1.0 1.5 2.0 2.5 3.0 INPUT COMMON MODE VOLTAGE (V) INPUT COMMON MODE VOLTAGE (V) INPUT COMMON MODE VOLTAGE (V) 6800 G01 2053 G02 6800 G03
Input Offset Voltage vs Input Input Offset Voltage vs Input Input Offset Voltage vs Input Common Mode Voltage, Common Mode Voltage, Common Mode Voltage 85°C ≤ TA ≤ 125°C 85°C ≤ TA ≤ 125°C
20 60 60 VS = 5V VS = 3V VS = 5V 15 VREF = 0V VREF = 0V VREF = 0V G = 10 40 G = 10 40 G = 10 10 20 20 5 0 0 0 T T A = 70°C A = 85°C TA = 85°C –5 T –20 –20 A = 25°C –10 INPUT OFFSET VOLTAGE (µV) INPUT OFFSET VOLTAGE (µV) INPUT OFFSET VOLTAGE (µV) –40 –40 –15 T T A = 125°C T A = –55°C A = 125°C –20 –60 –60 0 1 2 3 4 5 0 0.5 1.0 1.5 2.0 2.5 3.0 0 1 2 3 4 5 INPUT COMMON MODE VOLTAGE (V) INPUT COMMON MODE VOLTAGE (V) INPUT COMMON MODE VOLTAGE (V) 6800 G04 6800 G05 6800 G06 6800fb Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Related Parts Typical Application
