Datasheet LT1789-1, LT1789-10 (Analog Devices) - 2
DescriptionMicropower, Single Supply Rail-to-Rail Output Instrumentation Amplifier
Pages / Page24 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION …
File Format / SizePDF / 339 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LT1789-1/LT1789-10
Supply Voltage (V+ to V–)..36V TOP VIEW Input Differential Voltage ..36V R 1 8 R G G Input Current (Note 3) ... ±20mA –IN 2 7 +VS Output Short-Circuit Duration .. Indefinite +IN 3 6 OUT Operating Temperature Range ...–40°C to 85°C –VS 4 5 REF Specified Temperature Range (Note 4) S8 PACKAGE LT1789C-1, LT1789C-10 ...–40°C to 85°C 8-LEAD PLASTIC SO T LT1789I-1, LT1789I-10 ..–40°C to 85°C JMAX = 150°C, θJA = 190°C/W Storage Temperature Range .. –65°C to 150°C Lead Temperature (Soldering, 10 sec)... 300°C
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LT1789CS8-1#PBF LT1789CS8-1#TRPBF 17891 8-Lead Plastic SO –40°C to 85°C LT1789IS8-1#PBF LT1789IS8-1#TRPBF 1789I1 8-Lead Plastic SO –40°C to 85°C LT1789CS8-10#PBF LT1789CS8-10#TRPBF 178910 8-Lead Plastic SO –40°C to 85°C LT1789IS8-10#PBF LT1789IS8-10#TRPBF 789I10 8-Lead Plastic SO –40°C to 85°C
LEAD BASED FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LT1789CS8-1 LT1789CS8-1#TR 17891 8-Lead Plastic SO –40°C to 85°C LT1789IS8-1 LT1789IS8-1#TR 1789I1 8-Lead Plastic SO –40°C to 85°C LT1789CS8-10 LT1789CS8-10#TR 178910 8-Lead Plastic SO –40°C to 85°C LT1789IS8-10 LT1789IS8-10#TR 789I10 8-Lead Plastic SO –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/
3V AND 5V ELECTRICAL CHARACTERISTICS VS = 3V, 0V; VS = 5V, 0V; RL = 20k, VCM = VREF = half supply, TA = 25°C, unless otherwise noted. LT1789-1 LT1789-10 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
G Gain Range LT1789-1, G = 1 + (200k/RG) 1 1000 LT1789-10, G = 10 • [1+ (200k/RG)] 10 1000 Gain Error (Note 6) G = 1, VO = 0.1V to (+VS) – 1V 0.02 0.20 % LT1789-1, VO = 0.1V to (+VS) – 0.3V LT1789-10, VO = 0.2V to (+VS) – 0.3V G = 10 (Note 2) 0.06 0.25 0.01 0.25 % G = 100 (Note 2) 0.06 0.27 0.09 0.30 % G = 1000 (Note 2) 0.13 0.16 % Gain Nonlinearity (Note 6) G = 1, VO = 0.1V to (+VS) – 1V 35 100 ppm LT1789-1, VO = 0.1V to (+VS) – 0.3V LT1789-10, VO = 0.2V to 4.7V, VS = 5V (Note 8) G = 10 12 40 15 100 ppm G = 100 18 75 20 100 ppm G = 1000 90 100 ppm 1789fc 2
