LTC1100 WUTYPICAL PERFOR A CE CHARACTERISTICSLarge-Signal Transient ResponseSmall-Signal Transient ResponseOverload RecoveryG = 100, VS = ± 5VG = 100, VS = ± 5VG = 100, VS = ± 5V 1V/DIV 50mV/DIV 2V/DIV 2V/DIV 10µs/DIV 10µs/DIV 5µs/DIV LTC1100 • TPC13 LTC1100 • TPC14 LTC1100 • TPC15 Large-Signal Transient ResponseSmall-Signal Transient ResponseOverload RecoveryG = 10 (LTC1100CS Only), VS = ± 5VG = 10 (LTC1100CS Only), VS = ± 5VG = 10 (LTC1100CS Only), VS = ± 5V 1V/DIV 2V/DIV 50ms/DIV 2V/DIV 10µs/DIV 10µs/DIV 1µs/DIV LTC1100 • TPC16 LTC1100 • TPC17 LTC1100 • TPC18 UUUPI FU CTIO S8-Pin DIP (16-Pin SO)Pin 1 (2) GND REF: Connect to system ground. This sets suppressed by using the COMP pin. The standard com- the zero reference for the internal op amps. pensation circuit is a capacitor from COMP to VOUT, sized to provide an RC pole with the internal 247k resistor Pin 2 (4) CMRR: This pin tailors the gain of the internal (22.5k for LTC1100CS in gain-of-10 mode). See the amplifiers to maximize AC CMRR. For applications which Applications section. emphasize CMRR requirements, connect a 100k resistor and a 10pF capacitor in series from CMRR to ground. See Pin 8 (15) VOUT: Signal Output. the Applications section. 16-Pin SO Package OnlyPin 3 (6) –VIN: Inverting Input. (3) G = 10: Short to pin (2) for gain of 10. Leave Pin 4 (7) V– : Negative Supply. disconnected for gain of 100. Pin 5 (10) V+: Positive Supply. (14) G = 10: Short to pin (15) for gain of 10. Leave disconnected for gain of 100. Pin 6 (11) VIN: Noninverting Input. NOTE: Both pins must be shorted or open to provide Pin 7 (13) COMP: This pin reduces the bandwidth of the correct gain. internal amplifiers for applications at or near DC. Clock feedthrough from the internal sampling clock can also be (1),(5),(8),(9),(12),(16) NC : No Internal Connection. 1100fc 6
