Datasheet LT1101 (Analog Devices) - 2
DescriptionPrecision, Micropower, Single Supply Instrumentation Amplifier (Fixed Gain = 10 or 100)
Pages / Page16 / 2 — ABSOLUTE AXI U RATI GS (Note 1). (OBSOLETE). PACKAGE/ORDER I FOR ATIO. …
File Format / SizePDF / 244 Kb
ABSOLUTE AXI U RATI GS (Note 1). (OBSOLETE). PACKAGE/ORDER I FOR ATIO. OBSOLETE PACKAGES
ABSOLUTE AXI U RATI GS (Note 1) (OBSOLETE) PACKAGE/ORDER I FOR ATIO OBSOLETE PACKAGES
LT1101
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Supply Voltage .. ±22V Operating Temperature Range Differential Input Voltage ... ±36V LT1101AM/LT1101M
(OBSOLETE)
... – 55°C to 125°C Input Voltage ... Equal to Positive Supply Voltage LT1101AI/LT1101I .. – 40°C to 85°C ..10V Below Negative Supply Voltage LT1101AC/LT1101C .. 0°C to 70°C Output Short Circuit Duration .. Indefinite Storage Temperature Range ... – 65°C to 150°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW TOP VIEW TOP VIEW OUTPUT GROUND GROUND 8 OUT 1 8 OUTPUT NC 1 16 NC (REF) (REF) G = 10 1 90R 7 GND (REF) 2 15 OUTPUT 90R 90R 90R 90R REF OUT NC 3 14 NC 90R R R 9R 2 7 G = 10 G = 10 REF OUT REF 9R 9R 4 2 – 6 +IN R R G = 10 9R 9R 13 G = 10 G = 10 R R + –IN 5 12 +IN 9R – – +IN – – –IN 3 6 – + + NC 6 + + 11 NC + R ≈ 9.2k 3 5 V+ –IN R ≈ 9.2k V – 7 10 V + 4 4 5 V – V + NC 8 9 NC V– (CASE) H PACKAGE N PACKAGE 8-LEAD PDIP SW PACKAGE 8-LEAD TO-5 METAL CAN TJMAX = 150°C, θJA = 130°C/W 16-LEAD PLASTIC SO T J PACKAGE 8-LEAD CERDIP T JMAX = 150°C, θJA = 150°C/W, θJC = 45°C/W JMAX = 150°C, θJA = 100°C/W TJMAX = 150°C, θJA = 100°C/W ORDER PART ORDER PART ORDER PART NUMBER NUMBER NUMBER LT1101AMH LT1101AMJ8 LT1101AIN8 LT1101SW LT1101MH LT1101MJ8 LT1101IN8 LT1101ISW LT1101ACH LT1101ACJ8 LT1101ACN8 LT1101CH LT1101CJ8 LT1101CN8
OBSOLETE PACKAGES
Consider the N8 as an Alternate Source Consult LTC Marketing for parts specified with wider operating temperature ranges.
ELECTRICAL CHARACTERISTICS VS = 5V, 0V, VCM = 0.1V, VREF(PIN 1) = 0.1V, G = 10 or 100, TA = 25
C, unless otherwise noted. (Note 4) LT11O1AM/AI/AC LT1101M/I/C SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
GE Gain Error G = 100, V0 = 0.1V to 3.5V, RL = 50k 0.010 0.050 0.011 0.075 % G = 10, V0 = 0.1V to 3.5V, RL = 50k 0009 0.040 0.010 0.060 % GNL Gain Nonlinearity G = 100, RL = 50k 20 60 20 75 ppm G = 10, RL = 50k (Note 2) 3 7 3 8 ppm VOS Input Offset Voltage 50 160 60 220 µV LT1101SW 250 600 µV lOS Input Offset Current 0.13 0.60 0.15 0.90 nA IB Input Bias Current 6 8 6 10 nA IS Supply Current 75 105 78 120 µA 1101fa 2
