Datasheet LT6559 (Analog Devices) - 2
DescriptionLow Cost 5V/±5V 300MHz Triple Video Amplifier in 3mm x 3mm QFN
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. (Note 1). Order …
File Format / SizePDF / 451 Kb
ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. (Note 1). Order Options. The. 5V ELECTRICAL CHARACTERISTICS
ABSOLUTE MAXIMUM RATINGS PACKAGE/ORDER INFORMATION (Note 1) Order Options The 5V ELECTRICAL CHARACTERISTICS
LT6559
TOP VIEW Total Supply Voltage (V+ to V–) ..12.6V +IN R –IN R EN R OUT R Input Current (Note 2) ... ±10mA 16 15 14 13 Output Current .. ±100mA *GND 1 12 V+ Differential Input Voltage (Note 2) ..±5V –IN G 2 11 EN G 17 +IN G 3 10 OUT G Output Short-Circuit Duration (Note 3) .. Continuous *GND 4 9 V– Operating Temperature Range (Note 9) –40°C to 85°C 5 6 7 8 Specifi ed Temperature Range (Note 4) .. –40°C to 85°C +IN B –IN B EN B Storage Temperature Range .. –65°C to 125°C OUT B UD PACKAGE Junction Temperature (Note 5) .. 125°C 16-LEAD (3mm × 3mm) PLASTIC QFN TJMAX = 125°C, θJA = 68°C/W, θJC = 4.2°C/W EXPOSED PAD (PIN 17) IS V–, MUST BE SOLDERED TO THE PCB ORDER PART NUMBER UD PART MARKING LT6559CUD LCHG
Order Options
Tape and Reel: Add #TR Lead Free: Add #PBF Lead Free Tape and Reel: Add #TRPBF Lead Free Part Marking: http://www.linear.com/leadfree/ Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. * Ground pins are not internally connected. For best channel isolation, connect to ground.
denotes specifi cations which apply over the specifi ed operating temperature range, otherwise specifi cations are at TA = 25°C. For each amplifi er: VCM = 2.5V, VS = 5V,
E
N = 0V, pulse tested, unless otherwise noted. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 1.5 10 mV ● 12 mV ΔVOS/ΔT Input Offset Voltage Drift ● 15 µV/°C IIN+ Noninverting Input Current 10 25 µA ● 30 µA IIN– Inverting Input Current 10 60 µA ● 70 µA en Input Noise Voltage Density f = 1kHz, RF = 1k, RG = 10Ω, RS = 0Ω 4.5 nV/√⎯H⎯z +in Noninverting Input Noise Current f = 1kHz 6 pA/√⎯H⎯z Density –in Inverting Input Noise Current Density f = 1kHz 25 pA/√⎯H⎯z RIN Input Resistance VIN = ±1V 0.14 MΩ CIN Input Capacitance Amplifi er Enabled 2.0 pF Amplifi er Disabled 2.5 pF COUT Output Capacitance Amplifi er Disabled 8.5 pF VINH Input Voltage Range, High 3.5 4.0 V VINL Input Voltage Range, Low 1.0 1.5 V VOUTH Maximum Output Voltage Swing, High RL = 100k 4.1 4.15 V VOUTL Maximum Output Voltage Swing, Low RL = 100k 0.85 0.9 V VOUTH Maximum Output Voltage Swing, High RL = 150Ω 3.85 3.95 V RL = 150Ω ● 3.65 V 6559f 2
