Datasheet LT1395, LT1396, LT1397 (Analog Devices) - 5
DescriptionSingle 400MHz Current Feedback Amplifier
Pages / Page20 / 5 — ELECTRICAL CHARACTERISTICS. The
File Format / SizePDF / 332 Kb
LT1395/LT1396/LT1397
denotes specifi cations which apply over the specifi ed operating temperature range, otherwise specifi cations are at TA = 25°C. For each amplifi er: VCM = 0V, VS = ±5V, pulse tested, unless otherwise noted. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
tON Turn-On Delay Time (Note 9) RF = RG = 255Ω, RL = 100Ω, (LT1395CS6 only) 30 75 ns tOFF Turn-Off Delay Time (Note 9) RF = RG = 255Ω, RL = 100Ω, (LT1395CS6 only) 40 100 ns –3dB BW –3dB Bandwidth AV = 1, RF = 374Ω, RL = 100Ω 400 MHz AV = 2, RF = RG = 255Ω, RL = 100Ω 350 MHz 0.1dB BW 0.1dB Bandwidth AV = 1, RF = 374Ω, RL = 100Ω 100 MHz AV = 2, RF = RG = 255Ω, RL = 100Ω 100 MHz tr, tf Small-Signal Rise and Fall Time RF = RG = 255Ω, RL = 100Ω, VOUT = 1VP-P 1.3 ns tPD Propagation Delay RF = RG = 255Ω, RL = 100Ω, VOUT = 1VP-P 2.5 ns os Small-Signal Overshoot RF = RG = 255Ω, RL = 100Ω, VOUT = 1VP-P 10 % tS Settling Time 0.1%, AV = –1, RF = RG = 280Ω, RL = 150Ω 25 ns dG Differential Gain (Note 8) RF = RG = 255Ω, RL = 150Ω 0.02 % dP Differential Phase (Note 8) RF = RG = 255Ω, RL = 150Ω 0.04 DEG
Note 1:
Note 6:
TJ is calculated from the ambient temperature TA and the power may cause permanent damage to the device. Exposure to any Absolute dissipation PD according to the following formula: Maximum Rating condition for extended periods may affect device LT1395CS5: TJ = TA + (PD • 250°C/W) reliability and lifetime. LT1396CS6: TJ = TA + (PD • 230°C/W)
Note 2:
This parameter is guaranteed to meet specifi ed performance LT1395CS8: TJ = TA + (PD • 150°C/W) through design and characterization. It has not been tested. LT1396CS8: TJ = TA + (PD • 150°C/W)
Note 3:
A heat sink may be required depending on the power supply LT1396CMS8: T voltage and how many amplifi ers have their outputs short circuited. J = TA + (PD • 250°C/W) The θ LT1396CDD: T JA specifi ed for the DD package is with minimal PCB heat spreading J = TA + (PD • 160°C/W) metal. Using expanded metal area on all layers of a board reduces LT1397CS14: TJ = TA + (PD • 100°C/W) this value. LT1397CGN16: TJ = TA + (PD • 135°C/W)
Note 4:
The LT1395C/LT1396C/LT1397C are guaranteed functional over the LT1397CDE: TJ = TA + (PD • 43°C/W) operating temperature range of –40°C to 85°C. The LT1397H is guaranteed LT1397HDE: TJ = TA + (PD • 43°C/W) functional over the operating temperature range of –40°C to 125°C.
Note 7:
Slew rate is measured at ±2V on a ±3V output signal.
Note 5:
The LT1395C/LT1396C/LT1397C are guaranteed to meet specifi ed
Note 8:
Differential gain and phase are measured using a Tektronix performance from 0°C to 70°C. The LT1395C/LT1396C/LT1397C are TSG120YC/NTSC signal generator and a Tektronix 1780R Video designed, characterized and expected to meet specifi ed performance from Measurement Set. The resolution of this equipment is 0.1% and 0.1°. –40°C and 85°C but are not tested or QA sampled at these temperatures. Ten identical amplifi er stages were cascaded giving an effective resolution The LT1397H is guaranteed to meet specifi ed performance from –40°C to of 0.01% and 0.01°. 125°C. For guaranteed I-grade parts, consult the factory.
Note 9:
For LT1395CS6, turn-on delay time (tON) is measured from control input to appearance of 1V(50%) at the output, for VIN = 1V and AV = 2. Likewise, turn-off delay time (tOFF) is measured from control input to appearance of 1V(50%) on the output for VIN = 1V and AV = 2. This specifi cation is guaranteed by design and characterization. 139567fd 5
