Datasheet LT1210 (Analog Devices) - 7
Description | 1.1A, 35MHz Current Feedback Amplifier |
Pages / Page | 20 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Supply Current vs. Supply Current vs … |
Revision | C |
File Format / Size | PDF / 1.3 Mb |
TYPICAL PERFORMANCE CHARACTERISTICS. Supply Current vs. Supply Current vs Supply Voltage. Ambient Temperature, VS = ±5V
LT1210
TYPICAL PERFORMANCE CHARACTERISTICS Supply Current vs Supply Current vs Supply Current vs Supply Voltage Ambient Temperature, VS = ±5V Ambient Temperature, VS = ±15V
40 40 40 R A 38 SD = 0Ω V = 1 T 35 R R A = 25°C L = ∞ SD = 0Ω 35 R 36 SD = 0Ω 30 30 34 TA = 85°C 32 25 25 R R SD = 47.5kΩ SD = 7.5kΩ 30 20 20 TA = –40°C 28 TA = 125°C 15 15 26 R R SD = 15kΩ SD = 82.5kΩ SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) 10 SUPPLY CURRENT (mA) 10 24 A 22 5 5 V = 1 RL = ∞ 20 0 0 4 6 8 10 12 14 16 18 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 SUPPLY VOLTAGE (±V) TEMPERATURE (°C) TEMPERATURE (°C) 1210 G10 1210 G11 1210 G12
Supply Current vs Input Common Mode Limit vs Output Short-Circuit Current vs Shutdown Pin Current Junction Temperature Junction Temperature
40 V+ 3.0 VS = ±15V 35 –0.5 2.8 30 –1.0 SOURCING 2.6 –1.5 25 SINKING –2.0 2.4 20 2.0 2.2 15 1.5 SUPPLY CURRENT (mA) 2.0 10 COMMON MODE RANGE (V) 1.0 5 1.8 0.5 OUTPUT SHORT-CIRCUIT CURRENT (A) 0 V– 1.6 0 100 200 300 400 500 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 SHUTDOWN PIN CURRENT (µA) TEMPERATURE (°C) TEMPERATURE (°C) 1210 G13 1210 G14 1210 G15
Output Saturation Voltage vs Power Supply Rejection Ratio Supply Current vs Large-Signal Junction Temperature vs Frequency Output Frequency (No Load)
V+ 70 100 V RL = 50Ω AV = 2 –1 S = ±15V RL = 2kΩ V R 60 S = ±15V 90 L = ∞ –2 RL = 10Ω NEGATIVE RF = RG = 1kΩ VS = ±15V 80 VOUT = 20VP-P –3 50 POSITIVE –4 70 40 60 4 RL = 10Ω 30 50 3 20 SUPPLY CURRENT (mA) 40 2 RL = 2kΩ OUTPUT SATURATION VOLTAGE (V) POWER SUPPLY REJECTION (dB) 10 30 1 V– 0 20 –50 –25 0 25 50 75 100 125 10k 100k 1M 10M 100M 10k 100k 1M 10M TEMPERATURE (°C) FREQUENCY (Hz) FREQUENCY (Hz) 1210 G17 1210 G16 1210 G18 Rev C For more information www.analog.com 7 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Small-Signal Bandwidth Typical Performance Characteristics Applications Information Typical Applications Simplified Schematic Package Description Revision History Typical Application Related Parts
