Datasheet LT1259, LT1260 (Analog Devices) - 4
DescriptionLow Cost Dual and Triple 130MHz Current Feedback Amplifiers with Shutdown
Pages / Page12 / 4 — ELECTRICAL CHARACTERISTICS. Note 5:. Note 1:. Note 6:. Note 2:. Note 7:. …
File Format / SizePDF / 337 Kb
ELECTRICAL CHARACTERISTICS. Note 5:. Note 1:. Note 6:. Note 2:. Note 7:. Note 3:. Note 8:. Note 4:. TYPICAL AC PERFOR A CE. SMALL SIGNAL
ELECTRICAL CHARACTERISTICS Note 5: Note 1: Note 6: Note 2: Note 7: Note 3: Note 8: Note 4: TYPICAL AC PERFOR A CE SMALL SIGNAL
LT1259/LT1260
The ● denotes specifications which apply over the specified operating
Note 5:
The supply current of the LT1259/LT1260 has a negative temperature range. temperature coefficient. See Typical Performance Characteristics.
Note 1:
A heat sink may be required depending on the power supply
Note 6:
Slew rate is measured at ±5V on a ±10V output signal while voltage and how many amplifiers have their outputs short circuited. operating on ±15V supplies with RF = 1k, RG = 110Ω and RL = 1k.
Note 2:
Commercial grade parts are designed to operate over the
Note 7:
Turn-on delay time is measured while operating on ±5V temperature range of – 40°C to 85°C but are neither tested nor guaranteed supplies with RF = 1k, RG = 110Ω and RL = 150Ω. The tON is measured beyond 0°C to 70°C. Industrial grade parts specified and tested over from control input to appearance of 0.5V at the output, for VIN = 0.1V. – 40°C to 85°C are available on special request. Consult factory. Likewise, turn-off delay time is measured from control input to
Note 3:
Ground pins are not internally connected. For best appearance of 0.5V on the output for VIN = 0.1V. performance, connect to ground.
Note 8:
Differential gain and phase are measured using a Tektronix
Note 4:
TJ is calculated from the ambient temperature TA and the TSG120YC/NTSC signal generator and a Tektronix 1780R Video power dissipation PD according to the following formulas: Measurement Set. The resolution of this equipment is 0.1% and 0.1°. LT1259CN/LT1259IN: T Six identical amplifier stages were cascaded giving an effective J = TA + (PD • 70°C/W) LT1259CS/LT1259IS: T resolution of 0.016% and 0.016°. J = TA + (PD • 110°C/W) LT1260CNLT1260IN/: TJ = TA + (PD • 70°C/W) LT1260CS/LT1260IS: TJ = TA + (PD • 100°C/W)
W U TYPICAL AC PERFOR A CE SMALL SIGNAL SMALL SIGNAL SMALL SIGNAL VS (V) AV RL (
) RF (
) RG (
) – 3dB BW (MHz) 0.1dB BW (MHz) PEAKING (dB)
±12 2 150 1.5k 1.5k 130 53 0.1 ±5 2 150 1.1k 1.1k 93 40 0 ±12 10 150 1.1k 121 69 20 0.13 ±5 10 150 825 90.9 61 16 0
W U TYPICAL PERFOR A CE CHARACTERISTICS
12V Frequency Response, A
V = 2 12V Frequency Response, AV = 10
12 0 26 0 V 11 –20 25 S = ±12V R –20 PHASE L = 150Ω 10 –40 24 RF = 1.1k –40 PHASE RG = 121Ω 9 –60 23 –60 PHASE (DEG) PHASE (DEG) 8 –80 22 –80 7 –100 21 –100 GAIN GAIN GAIN (dB) 6 –120 GAIN (dB) 20 –120 5 –140 19 –140 4 V –160 18 –160 S = ±12V R 3 L = 150Ω –180 17 –180 RF = RG = 1.5k 2 –200 16 –200 1 10 100 1 10 100 FREQUENCY (MHz) FREQUENCY (MHz) LT1259/60 • TPC01 LT1259/60 • TPC01 4
