Datasheet LT1204 (Analog Devices) - 2
Description4-Input Video Multiplexer with 75MHz Current Feedback Amplifier
Pages / Page20 / 2 — ABSOLUTE. AXI U. R TI GS. PACKAGE/ORDER I FOR ATIO. ELECTRICAL CH. ARA …
File Format / SizePDF / 272 Kb
ABSOLUTE. AXI U. R TI GS. PACKAGE/ORDER I FOR ATIO. ELECTRICAL CH. ARA TERISTICS
ABSOLUTE AXI U R TI GS PACKAGE/ORDER I FOR ATIO ELECTRICAL CH ARA TERISTICS
LT1204
W W W U ABSOLUTE AXI U A R TI GS
Supply Voltage ... ±18V Operating Temperature Range ... – 40°C to 85°C – Input Current (Pin 13) .. ±15mA Storage Temperature Range .. – 65°C to 150°C +Input and Control/Logic Current (Note 1) .. ±50mA Junction Temperature (Note 4) .. 150°C Output Short-Circuit Duration (Note 2) ... Continuous Lead Temperature (Soldering, 10 sec).. 300°C Specified Temperature Range (Note 3) ... 0°C to 70°C
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW ORDER PART TOP VIEW ORDER PART NUMBER V 1 16 IN0 V+ NUMBER V 1 16 IN0 V+ GND 2 15 V GND 2 15 V O O V 3 14 V– LT1204CN* V 3 14 IN1 V– LT1204CSW* IN1 GND 4 13 FB GND 4 13 FB V 5 12 V 5 12 IN2 SHDN IN2 SHDN GND 6 11 ENABLE GND 6 11 ENABLE V 7 10 V 7 10 IN3 A1 IN3 A1 REF 8 9 A0 REF 8 9 A0 N PACKAGE SW PACKAGE 16-LEAD PDIP 16-LEAD PLASTIC SO T *See Note 3 *See Note 3 JMAX = 150°C, θJA = 70°C/W TJMAX = 150°C, θJA = 90°C/W Consult factory for Industrial and Military grade parts.
ELECTRICAL CH C ARA TERISTICS 0
C
TA
70
C,
5V
VS
15V, VCM = 0V, Pin 8 grounded and pulse tested unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage Any Positive Input, TA = 25°C 5 14 mV ● 16 mV Offset Matching Between Any Positive Input, VS = ±15V ● 0.5 5 mV Input Offset Voltage Drift Any Positive Input ● 40 µV/°C I + IN Positive Input Bias Current Any Positive Input, TA = 25°C 3 8 µA ● 10 µA I – IN Negative Input Bias Current TA = 25°C ±20 ±100 µA ● ±150 µA en Input Noise Voltage f = 1kHz, RF = 1k, RG = 10Ω, RS = 0Ω 7 nV/√Hz + in Noninverting Input Noise Current Density f = 1kHz 1.5 pA/√Hz – in Inverting Input Noise Current Density f = 1kHz 40 pA/√Hz CIN Input Capacitance Input Selected 3.0 pF Input Deselected 3.5 pF COUT Output Capacitance Disabled, Pin 11 Voltage = 0V 8 pF RIN Positive Input Resistance, Any Positive Input VS = ±5V, VIN = – 1.5V, 2V, TA = 25°C 5 20 MΩ VS = ±15V, VIN = ±5V ● 4 20 MΩ 2
