Datasheet LT1358, LT1359 (Analog Devices) - 6
DescriptionDual and Quad 25MHz, 600V/µs Op Amps
Pages / Page16 / 6 — TYPICAL PERFOR A CE CHARACTERISTICS. Supply Current vs Supply Voltage. …
File Format / SizePDF / 489 Kb
TYPICAL PERFOR A CE CHARACTERISTICS. Supply Current vs Supply Voltage. Input Common Mode Range vs. Input Bias Current vs
TYPICAL PERFOR A CE CHARACTERISTICS Supply Current vs Supply Voltage Input Common Mode Range vs Input Bias Current vs
LT1358/LT1359
W U TYPICAL PERFOR A CE CHARACTERISTICS Supply Current vs Supply Voltage Input Common Mode Range vs Input Bias Current vs and Temperature Supply Voltage Input Common Mode Voltage
3.0 V + 400 T V – 0.5 A = 25°C S = ±15V ∆VOS < 1mV T 300 A = 25°C + – 2.5 –1.0 + I I B B = IB ———— 125°C –1.5 2 200 2.0 –2.0 25°C 100 – 55°C 1.5 2.0 0 1.5 SUPPLY CURRENT (mA) INPUT BIAS CURRENT (nA) 1.0 COMMON MODE RANGE (V) 1.0 –100 0.5 0.5 V – –200 0 5 10 15 20 0 5 10 15 20 –15 –10 –5 0 5 10 15 SUPPLY VOLTAGE (±V) SUPPLY VOLTAGE (±V) INPUT COMMON MODE VOLTAGE (V) 135859 G01 135859 G02 135859 G03
Input Bias Current vs Open-Loop Gain vs Temperature Input Noise Spectral Density Resistive Load
450 100 10 100 V V S = ±15V V S = ±15V T 400 S = ±15V A = 25°C I + + I – T INPUT CURRENT NOISE (pA/ I B B B =⏐ ⏐ ———— A = 25°C 350 2 Hz) AV = 101 90 VS = ±5V RS = 100k 300 80 250 en 10 1 200 70 150 in OPEN-LOOP GAIN (dB) INPUT BIAS CURRENT (nA) Hz) 100 60 INPUT VOLTAGE NOISE (nV/ 50 0 1 0.1 50 – 50 –25 0 25 50 75 100 125 10 100 1k 10k 100k 10 100 1k 10k TEMPERATURE (°C) FREQUENCY (Hz) LOAD RESISTANCE (Ω) 135859 G04 135859 G05 135859 G06
Output Voltage Swing vs Output Voltage Swing vs Open-Loop Gain vs Temperature Supply Voltage Load Current
101 V + V + –0.5 V 85°C S = ±15V TA = 25°C VS = ±5V 100 R R –1.0 L = 1k –1 L = 1k VIN = 100mV VO = ±12V –1.5 – 40°C 99 –2 RL = 500Ω –2.0 98 –3 –2.5 25°C 25°C 97 3 2.5 96 RL = 500Ω 85°C 2.0 OPEN-LOOP GAIN (dB) 2 95 – 40°C OUTPUT VOLTAGE SWING (V) OUTPUT VOLTAGE SWING (V) 1.5 94 1 RL = 1k 1.0 93 V – V –+0.5 – 50 –25 0 25 50 75 100 125 0 5 10 15 20 – 50 – 40 –30 –20 –10 0 10 20 30 40 50 TEMPERATURE (°C) SUPPLY VOLTAGE (±V) OUTPUT CURRENT (mA) 135859 G07 135859 G08 135859 G09 135859fb 6
