Datasheet LT1220 (Analog Devices) - 2
Description45MHz, 250V/µs Operational Amplifier
Pages / Page12 / 2 — ABSOLUTE. AXI U. R TI GS (Note 1). (OBSOLETE) ... (OBSOLETE) .. …
File Format / SizePDF / 273 Kb
ABSOLUTE. AXI U. R TI GS (Note 1). (OBSOLETE) ... (OBSOLETE) .. PACKAGE/ORDER I FOR ATIO. OBSOLETE PACKAGE
ABSOLUTE AXI U R TI GS (Note 1) (OBSOLETE) .. (OBSOLETE) . PACKAGE/ORDER I FOR ATIO OBSOLETE PACKAGE
LT1220
W W W U ABSOLUTE AXI U A R TI GS (Note 1)
Total Supply Voltage (V+ to V–) .. 36V Operating Temperature Range Differential Input Voltage .. ±6V LT1220C ... – 40°C TO 85°C Input Voltage .. ±VS LT1220M
(OBSOLETE) ...
– 55°C to 150°C Output Short-Circuit Duration (Note 2) ... Indefinite Maximum Junction Temperature (See Below) Specified Temperature Range Plastic Package ... 150°C LT1220C (Note 3) ... 0°C to 70°C Ceramic Package
(OBSOLETE) ..
175°C LT1220M
(OBSOLETE) ...
– 55°C to 125°C Storage Temperature Range .. – 65°C to 150°C Lead Temperature (Soldering, 10 sec)... 300°C
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW TOP VIEW ORDER PART ORDER PART NULL NUMBER NULL 1 8 NULL NUMBER 8 –IN 2 7 V+ NULL 1 7 V+ LT1220CN8 LT1220CH +IN 3 6 VOUT LT1220CS8 –IN 2 6 VOUT LT1220MH V – 4 5 NC S8 PART MARKING +IN 3 5 NC N8 PACKAGE S8 PACKAGE 4 8-LEAD PLASTIC DIP 8-LEAD PLASTIC SOIC V – 1220 TJMAX = 150°C, θJA = 130°C/W (N) H PACKAGE TJMAX = 150°C, θJA = 190°C/W (S) 8-LEAD TO-5 METAL CAN J8 PACKAGE TJMAX = 175°C, θJA = 150°C/W 8-LEAD CERAMIC DIP ORDER PART TJMAX = 175°C, θJA = 100°C/W (J) NUMBER
OBSOLETE PACKAGE
LT1220MJ8
OBSOLETE PACKAGE
Consider the N8 or S8 Packages for Alternate Source Consider the N8 Package for Alternate Source Consult LTC Marketing for parts specified with wider operating temperature ranges.
ELECTRICAL CHARACTERISTICS TA = 25
C, VS =
15V, VCM = 0V, unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 4) 0.5 1 mV IOS Input Offset Current 100 300 nA IB Input Bias Current 100 300 nA en Input Noise Voltage f = 10kHz 17 nV/√Hz in Input Noise Current f = 10kHz 2 pA/√Hz RIN Input Resistance VCM = ±12V 20 45 MΩ Differential 150 kΩ CIN Input Capacitance 2 pF Input Voltage Range (Positive) 12 14 V Input Voltage Range (Negative) – 13 – 12 V CMRR Common Mode Rejection Ratio VCM = ±12V 92 114 dB PSRR Power Supply Rejection Ratio VS = ±5V to ±15V 90 94 dB AVOL Large-Signal Voltage Gain VOUT = ±10V, RL = 500Ω 20 50 V/mV VOUT Output Swing RL = 500Ω 12 13 ±V IOUT Output Current VOUT = ±12V 24 26 mA SR Slew Rate (Note 5) 200 250 V/µs Full Power Bandwidth 10V Peak (Note 6) 4 MHz GBW Gain-Bandwidth f = 1MHz 45 MHz 2
