Datasheet LT6553 (Analog Devices) - 4
Description650MHz Gain of 2 Triple Video Amplifier
Pages / Page12 / 4 — TYPICAL PERFOR A CE CHARACTERISTICS. Supply Current per Amplifier vs. …
File Format / SizePDF / 199 Kb
TYPICAL PERFOR A CE CHARACTERISTICS. Supply Current per Amplifier vs. Temperature. Supply Voltage. EN Pin Voltage
TYPICAL PERFOR A CE CHARACTERISTICS Supply Current per Amplifier vs Temperature Supply Voltage EN Pin Voltage
LT6553
W U TYPICAL PERFOR A CE CHARACTERISTICS Supply Current per Amplifier vs Supply Current per Amplifier vs Supply Current per Amplifier vs Temperature Supply Voltage EN Pin Voltage
12 12 12 VS = ±5V V– = –V+ VS = ±5V RL = ∞ V V EN, VDGND, VIN = 0V DGND = 0V T 10 V A = –55°C IN = 0V 10 TA = 25°C 10 VIN = 0V VEN = 0V TA = 25°C 8 8 8 TA = 125°C VEN = 0.4V 6 6 6 4 4 4 SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) 2 2 2 0 0 0 –55 –35 –15 5 25 45 65 85 105 125 0 1 2 3 4 5 6 7 8 9 10 11 12 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 TEMPERATURE (°C) TOTAL SUPPLY VOLTAGE (V) EN PIN VOLTAGE (V) 6553 G01 6553 G02 6553 G03
Input Referred Offset Voltage vs Input Bias Current vs Temperature Input Voltage EN Pin Current vs EN Pin Voltage
10.0 20 0 V V S = ±5V S = ±5V VS = ±5V V V 7.5 IN = 0V –20 DGND = 0V 5.0 µA) 0 T –40 A = 125°C µA) 2.5 –60 TA = 125°C 0 –20 TA = 25°C TA = –55°C –80 –2.5 TA = –55°C TA = 25°C OFFSET VOLTAGE (mV) EN PIN CURRENT ( –100 –5.0 INPUT BIAS CURRENT ( –40 –120 –7.5 –10.0 –60 –140 –55 –35 –15 5 25 45 65 85 105 125 –2.5 –1.5 –0.5 0.5 1.5 2.5 0 1 2 3 4 5 TEMPERATURE (°C) INPUT VOLTAGE (V) EN PIN VOLTAGE (V) 6553 G04 6553 G05 6553 G06
Output Voltage Swing vs ILOAD Output Voltage Swing vs ILOAD Output Voltage vs Input Voltage (Output High) (Output Low)
5 5 0 VS = ±5V VS = ±5V VS = ±5V 4 RL = 150Ω TA = 125°C VIN = 2V VIN = –2V 3 4 –1 T 2 A = 25°C TA = 25°C TA = –55°C 1 3 –2 TA = 125°C 0 TA = 25°C –1 2 –3 TA = –55°C –2 TA = 125°C OUTPUT VOLTAGE (V) TA = –55°C OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) –3 1 –4 –4 –5 0 –5 –2.5 –1.5 –0.5 0.5 1.5 2.5 0 10 20 30 40 50 60 70 80 90 100 0 10 20 30 40 50 60 70 80 90 100 INPUT VOLTAGE (V) SOURCE CURRENT (mA) SINK CURRENT (mA) 6553 G07 6553 G08 6553 G09 6553f 4
