LT1739 Dual 500mA, 200MHz xDSL Line Driver Amplifier UFEATURESDESCRIPTIO ■ 3mm × 4mm High Power DFN Package The LT®1739 is a 500mA minimum output current, dual op ■ Exceeds All Requirements For Full Rate, amp with outstanding distortion performance. The ampli- Downstream ADSL Line Drivers fiers are gain-of-ten stable, but can be easily compensated ■ ± 500mA Minimum IOUT for lower gains. The extended output swing allows for ■ ± 11.1V Output Swing, VS = ± 12V, RL = 100 Ω lower supply rails to reduce system power. Supply current ■ ± 10.9V Output Swing, VS = ± 12V, IL = 250mA is set with an external resistor to optimize power dissipa- ■ Low Distortion: – 82dBc at 1MHz, 2VP-P Into 50 Ω tion. The LT1739 features balanced, high impedance in- ■ Power Saving Adjustable Supply Current puts with low input bias current and input offset voltage. ■ Power Enhanced TSSOP-20 Small Footprint Package Active termination is easily implemented for further sys- ■ 200MHz Gain Bandwidth tem power reduction. Short-circuit protection and thermal ■ 600V/µs Slew Rate shutdown insure the device’s ruggedness. ■ Specified at ±12V and ±5V The outputs drive a 100Ω load to ±11.1V with ±12V U supplies, and ±10.9V with a 250mA load. The LT1739 is a APPLICATIO S pin-for-pin replacement for the LT1794 in xDSL line driver applications and requires no circuit changes. ■ High Density ADSL Central Office Line Drivers ■ High Efficiency ADSL, HDSL2, G.lite, The LT1739 is available in the very small, thermally SHDSL Line Drivers enhanced, 3mm × 4mm DFN package or a 20-lead TSSOP ■ Buffers for maximum port density in central office line driver ■ Test Equipment Amplifiers applications. For a dual version of the LT1739, see the ■ Cable Drivers LT6301 data sheet. , LTC and LT are registered trademarks of Linear Technology Corporation. UTYPICAL APPLICATIOHigh Efficiency ± 12V Supply ADSL Central Office Line Driver 12V 3mm × 4mm DFN Package RBIAS Bottom View 24.9k +IN + SHDN 1/2 12.7Ω LT1739 EXPOSED – THERMAL PAD 1k 1:2* 110Ω 0.8mm • • 100Ω 1000pF 110Ω 1739 TA01 1k 1739 TA02 3mm 4mm – *COILCRAFT X8390-A OR EQUIVALENT ISUPPLY = 10mA PER AMPLIFIER 1/2 12.7Ω WITH RBIAS = 24.9k LT1739 SHDNREF –IN + –12V 1739fas, sn1739 1
