Datasheet LT1794 (Analog Devices) - 2
DescriptionDual 500mA, 200MHz xDSL Line Driver Amplifier
Pages / Page20 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PACKAGE/ORDER INFORMATION. ELECTRICAL …
File Format / SizePDF / 287 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PACKAGE/ORDER INFORMATION. ELECTRICAL CHARACTERISTICS. The
ABSOLUTE MAXIMUM RATINGS (Note 1) PACKAGE/ORDER INFORMATION ELECTRICAL CHARACTERISTICS The
LT1794
W W W U ABSOLUTE MAXIMUM RATINGS (Note 1)
Supply Voltage (V + to V –) .. ±18V Specified Temperature Range (Note 3) .. – 40°C to 85°C Input Current ... ±10mA Junction Temperature .. 150°C Output Short-Circuit Duration (Note 2) ... Indefinite Storage Temperature Range ... – 65°C to 150°C Operating Temperature Range ... – 40°C to 85°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER INFORMATION
TOP VIEW ORDER PART ORDER PART NUMBER TOP VIEW NUMBER V– 1 20 V– NC 1 20 NC NC 2 19 NC LT1794CFE V+ 2 19 V+ LT1794CSW –IN 3 18 OUT LT1794IFE OUT 3 18 OUT LT1794ISW +IN 4 17 V+ V– 4 17 V– SHDN 5 16 NC V– 5 16 V– SHDNREF 6 15 NC V– 6 15 V– +IN 7 14 V+ V– 7 14 V– –IN 8 13 OUT –IN 8 13 –IN NC 9 12 NC +IN 9 12 +IN V– 10 11 V– SHDN 10 11 SHDNREF FE PACKAGE SW PACKAGE 20-LEAD PLASTIC TSSOP 20-LEAD PLASTIC SO TJMAX = 150°C, θJA = 40°C/W, θJC = 3°C/W (Note 4) TJMAX = 150°C, θJA = 40°C/W, θJC = 3°C/W (Note 4) UNDERSIDE METAL CONNECTED TO V– Consult factory for parts specified with wider operating temperature ranges.
denotes the specifications which apply over the full specified temperature range, otherwise specifications are at TA = 25
C. VCM = 0V, pulse tested,
5V
VS
15V, VSHDNREF = 0V, RBIAS = 24.9k between V + and SHDN unless otherwise noted. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 1 5.0 mV ● 7.5 mV Input Offset Voltage Matching 0.3 5.0 mV ● 7.5 mV Input Offset Voltage Drift ● 10 µV/°C IOS Input Offset Current 100 500 nA ● 800 nA IB Input Bias Current ±0.1 ±4 µA ● ±6 µA Input Bias Current Matching 100 500 nA ● 800 nA en Input Noise Voltage Density f = 10kHz 8 nV/√Hz in Input Noise Current Density f = 10kHz 0.8 pA/√Hz RIN Input Resistance VCM = (V+ – 2V) to (V–+ 2V) ● 5 50 MΩ Differential 6.5 MΩ 2
