Datasheet LT6203X (Analog Devices) - 3
DescriptionHigh Temperature 175°C Dual 100MHz, Rail-to-Rail Input and Output, Ultralow 1.9nV/√Hz Noise, Low Power Op Amp
Pages / Page16 / 3 — elecTrical characTerisTics. TA = 25°C, VS =5V, 0V; VS = 3V, 0V; VCM = …
elecTrical characTerisTics. TA = 25°C, VS =5V, 0V; VS = 3V, 0V; VCM = VOUT = half supply,. unless otherwise noted. SYMBOL
elecTrical characTerisTics TA = 25°C, VS =5V, 0V; VS = 3V, 0V; VCM = VOUT = half supply, unless otherwise noted SYMBOL
LT6203X
elecTrical characTerisTics TA = 25°C, VS =5V, 0V; VS = 3V, 0V; VCM = VOUT = half supply, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IOS Input Offset Current VCM = Half Supply 0.12 1 µA VCM = V+ 0.07 1 µA VCM = V– 0.12 1.1 µA Input Noise Voltage 0.1Hz to 10Hz 800 nVP-P en Input Noise Voltage Density f = 100kHz, VS = 5V 2 nV/√Hz f = 10kHz, VS = 5V 2.9 4.5 nV/√Hz in Input Noise Current Density, Balanced f = 10kHz, VS = 5V 0.75 pA/√Hz Input Noise Current Density, Unbalanced 1.1 pA/√Hz Input Resistance Common Mode 4 MΩ Differential Mode 12 kΩ CIN Input Capacitance Common Mode 1.8 pF Differential Mode 1.5 pF AVOL Large Signal Gain VS = 5V, VO = 0.5V to 4.5V, RL = 1k to VS/2 40 70 V/mV VS = 5V, VO = 1V to 4V, RL = 100 to VS/2 8.0 14 V/mV VS = 3V, VO = 0.5V to 2.5V, RL = 1k to VS/2 17 40 V/mV CMRR Common Mode Rejection Ratio VS = 5V, VCM = V– to V+ 60 83 dB VS = 5V, VCM = 1.5V to 3.5V 80 100 dB VS = 3V, VCM = V– to V+ 56 80 dB CMRR Match (Channel-to-Channel) (Note 5) VS = 5V, VCM = 1.5V to 3.5V 85 120 dB PSRR Power Supply Rejection Ratio VS = 2.5V to 10V, VCM = 0V 60 74 dB PSRR Match (Channel-to-Channel) (Note 5) VS = 2.5V to 10V, VCM = 0V 70 100 dB Minimum Supply Voltage (Note 6) 2.5 V VOL Output Voltage Swing LOW Saturation No Load 5 50 mV (Note 7) ISINK = 5mA 85 190 mV VS = 5V, ISINK = 20mA 240 460 mV VS = 3V, ISINK = 15mA 185 350 mV VOH Output Voltage Swing HIGH Saturation No Load 25 75 mV (Note 7) ISOURCE = 5mA 90 210 mV VS = 5V, ISOURCE = 20mA 325 600 mV VS = 3V, ISOURCE = 15mA 225 410 mV ISC Short-Circuit Current VS = 5V ±30 ±45 mA VS = 3V ±25 ±40 mA IS Supply Current per Amp VS = 5V 2.5 3.0 mA VS = 3V 2.3 2.85 mA GBW Gain Bandwidth Product Frequency = 1MHz, VS = 5V 90 MHz SR Slew Rate VS = 5V, AV = –1, RL = 1k, VO = 4V 17 24 V/µs FPBW Full Power Bandwidth (Note 9) VS = 5V, VOUT = 3VP-P 1.8 2.5 MHz tS Settling Time 0.1%, VS = 5V, VSTEP = 2V, AV = –1, RL = 1k 85 ns 6203xf For more information www.linear.com/LT6203X 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Electrical Characteristics Typical Performance Characteristics Applications Information Typical Application Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Applications Information Package Description Typical Application Related Parts
