Datasheet LTC6252, LTC6253, LTC6254 (Analog Devices) - 3
Description720MHz, 3.5mA Quad Power Efficient Rail-to-Rail I/O Op Amps
Pages / Page26 / 3 — ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*. PACKAGE …
File Format / SizePDF / 968 Kb
ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*. PACKAGE DESCRIPTION. SPECIFIED TEMPERATURE RANGE
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LTC6252/LTC6253/LTC6254
LTC6253CMS#PBF LTC6253CMS#TRPBF LTFSB 10-Lead Plastic MSOP 0°C to 70°C LTC6253IMS#PBF LTC6253IMS#TRPBF LTFSB 10-Lead Plastic MSOP –40°C to 85°C LTC6254CMS#PBF LTC6254CMS#TRPBF 6254 16-Lead Plastic MSOP 0°C to 70°C LTC6254IMS#PBF LTC6254IMS#TRPBF 6254 16-Lead Plastic MSOP –40°C to 85°C LTC6254HMS#PBF LTC6254HMS#TRPBF 6254 16-Lead Plastic MSOP –40°C to 125°C TRM = 500 pieces. *Temperature grades are identified by a label on the shipping container. Consult LTC Marketing for parts specified with wider operating temperature ranges. Consult LTC Marketing for information on lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/
ELECTRICAL CHARACTERISTICS (VS = 5V) The
l
denotes the specifications which apply across the specified temperature range, otherwise specifications are at TA = 25°C. For each amplifier VS = 5V, 0V; VSHDN = 2V; VCM = VOUT = 2.5V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = Half Supply –350 50 350 µV l –1000 1000 µV VCM = V+ – 0.5V, NPN Mode –2.2 0.1 2.2 mV l –3.3 –3.3 mV DVOS Input Offset Voltage Match VCM = Half Supply –350 50 350 µV (Channel-to-Channel) (Note 8) l –550 550 µV VCM = V+ – 0.5V, NPN Mode –2.75 0.1 2.75 mV l –4 4 mV VOS TC Input Offset Voltage Drift l –3.5 µV/°C IB Input Bias Current (Note 7) VCM = Half Supply –0.75 –0.1 0.75 µA l –1.15 1.15 µA VCM = V+ – 0.5V, NPN Mode 0.8 1.4 3.0 µA l 0.4 5.0 µA IOS Input Offset Current VCM = Half Supply –0.5 –0.03 0.5 µA l –0.6 0.6 µA VCM = V+ – 0.5V, NPN Mode –0.5 –0.03 0.5 µA l –0.6 0.6 µA en Input Noise Voltage Density f = 1MHz 2.75 nV/√Hz Input 1/f Noise Voltage f = 0.1Hz to 10Hz 2 µVP-P in Input Noise Current Density f = 1MHz 4 pA/√Hz CIN Input Capacitance Differential Mode 2.5 pF Common Mode 0.8 pF RIN Input Resistance Differential Mode 7.2 kΩ Common Mode 3 MΩ AVOL Large Signal Voltage Gain RL = 1k to Half Supply (Note 10) 35 60 V/mV l 16 V/mV RL = 100Ω to Half Supply (Note 10) 5 13 V/mV l 2.4 V/mV CMRR Common Mode Rejection Ratio VCM = 0V to 3.5V 85 105 dB l 82 dB 625234fc 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
