Datasheet LTC6246, LTC6247, LTC6248 (Analog Devices) - 3
Description180MHz, 1mA Power Efficient Rail-to-Rail I/O Op Amps
Pages / Page26 / 3 — ORDER INFORMATION http://www.linear.com/product/LTC6246#orderinfo. LEAD …
RevisionC
File Format / SizePDF / 764 Kb
ORDER INFORMATION http://www.linear.com/product/LTC6246#orderinfo. LEAD FREE FINISH. TAPE AND REEL
ORDER INFORMATION http://www.linear.com/product/LTC6246#orderinfo LEAD FREE FINISH TAPE AND REEL
LTC6246/LTC6247/LTC6248
ORDER INFORMATION http://www.linear.com/product/LTC6246#orderinfo LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LTC6246CS6#TRMPBF LTC6246CS6#TRPBF LTDWF 6-Lead Plastic TSOT-23 0°C to 70°C LTC6246IS6#TRMPBF LTC6246IS6#TRPBF LTDWF 6-Lead Plastic TSOT-23 –40°C to 85°C LTC6246HS6#TRMPBF LTC6246HS6#TRPBF LTDWF 6-Lead Plastic TSOT-23 –40°C to 125°C
OBSOLETE
LTC6247CKC#TRMPBF LTC6247CKC#TRPBF DWJT 8-Lead (2mm × 2mm × 0.6mm) UTDFN 0°C to 70°C LTC6247IKC#TRMPBF LTC6247IKC#TRPBF DWJT 8-Lead (2mm × 2mm × 0.6mm) UTDFN –40°C to 85°C LTC6247CMS8#PBF LTC6247CMS8#TRPBF LTDWH 8-Lead Plastic MSOP 0°C to 70°C LTC6247IMS8#PBF LTC6247IMS8#TRPBF LTDWH 8-Lead Plastic MSOP –40°C to 85°C LTC6247CTS8#TRMPBF LTC6247CTS8#TRPBF LTDWK 8-Lead Plastic TSOT-23 0°C to 70°C LTC6247ITS8#TRMPBF LTC6247ITS8#TRPBF LTDWK 8-Lead Plastic TSOT-23 –40°C to 85°C LTC6247HTS8#TRMPBF LTC6247HTS8#TRPBF LTDWK 8-Lead Plastic TSOT-23 –40°C to 125°C LTC6247CMS#PBF LTC6247CMS#TRPBF LTDWM 10-Lead Plastic MSOP 0°C to 70°C LTC6247IMS#PBF LTC6247IMS#TRPBF LTDWM 10-Lead Plastic MSOP –40°C to 85°C LTC6247CDC#TRMPBF LTC6247CDC#TRPBF LGVN 8-Lead (2mm × 2mm × 0.8mm) DFN 0°C to 70°C LTC6247IDC#TRMPBF LTC6247IDC#TRPBF LGVN 8-Lead (2mm × 2mm × 0.8mm) DFN –40°C to 85°C LTC6248CMS#PBF LTC6248CMS#TRPBF 6248 16-Lead Plastic MSOP 0°C to 70°C LTC6248IMS#PBF LTC6248IMS#TRPBF 6248 16-Lead Plastic MSOP –40°C to 85°C LTC6248HMS#PBF LTC6248HMS#TRPBF 6248 16-Lead Plastic MSOP –40°C to 125°C TRM = 500 pieces. *Temperature grades are identified by a label on the shipping container. Consult ADI Marketing for parts specified with wider operating temperature ranges. Consult ADI Marketing for information on lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/
ELECTRICAL CHARACTERISTICS (VS = 5V) The
denotes the specifications which apply across the specified temperature range, otherwise specifications are at TA = 25°C. For each amplifier VS = 5V, 0V; VSHDN = 2V; VCM = VOUT = 2.5V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = Half Supply –500 50 500 µV l –1000 1000 µV VCM = V+ – 0.5V, NPN Mode –2.5 0.1 2.5 mV l –3 3 mV ∆VOS Input Offset Voltage Match VCM = Half Supply –600 50 600 µV (Channel-to-Channel) (Note 8) l –1000 1000 µV VCM = V+ – 0.5V, NPN Mode –3.5 0.1 3.5 mV l –4 4 mV VOS TC Input Offset Voltage Drift l –2 µV/°C IB Input Bias Current (Note 7) VCM = Half Supply –350 –30 350 nA l –550 550 nA VCM = V+ – 0.5V, NPN Mode 100 400 1000 nA l 0 1500 nA Rev C For more information www.analog.com 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Typical Applications Revision History Typical Application Related Parts
