Datasheet RH1814M (Analog Devices) - 7
DescriptionQuad 3mA, 100MHz, 750V/µs Operational Amplifier
Pages / Page8 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Offset Voltage. Input Bias …
File Format / SizePDF / 625 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Input Offset Voltage. Input Bias Current. Input Offset Current. Open-Loop Gain
TYPICAL PERFORMANCE CHARACTERISTICS Input Offset Voltage Input Bias Current Input Offset Current Open-Loop Gain
RH1814M
1.5 7 1.5 VS = ±5V VS = ±5V VS = ±5V VCM = 0V VCM = 0V VCM = 0V 1.0 6 1.0 5 0.5 4 0.5 0 3 0 –0.5 2 INPUT OFFSET VOLTAGE (mV) INPUT BIAS CURRENT (µA) –0.5 –1.0 INPUT OFFSET CURRENT (µA) 1 –1.5 0 –1.0 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1814M G04 RH1814M G05 RH1814M G06
Open-Loop Gain Common Mode Rejection Ratio
70 100 VS = ±5V V R S = ±5V 68 L = 10k 1.5V ≤ VCM ≤ 3.5V V 95 OUT = ±3V 66 90 64 85 62 80 OPEN-LOOP GAIN (dB) 60 75 58 70 COMMON MODE REJECTION RATIO (dB) 56 65 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1814M G07 RH1814M G08
Power Supply Rejection Ratio Gain-Bandwidth Product
105 120 VS = ±2V TO ±5.5V VS = ±5V R 100 L = 10k 110 95 90 100 85 80 90 75 GAIN BANDWIDTH PRODUCT (MHz) POWER SUPPLY REJECTION RATIO (dB) 70 80 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH1814M G09 RH1814M G11 1814mfb Information furnished by Linear Technology Corporation is believed to be accurate and reliable. However, no responsibility is assumed for its use. Linear Technology Corporation makes no representa- tion that the interconnection of its circuits as described herein will not infringe on existing patent rights. 7 Document Outline Description Absolute Maximum Ratings Electrical Characteristics Burn-In Circuit Package Information Table 1: Electrical Characteristics Table 2: Electrical Characteristics Table 1: Electrical Characteristics Table 2: Electrical Characteristics TABLE 2: Electrical Test Requirements Total Dose Bias Circuit Typical Performance Characteristics Revision History
