Datasheet LT6233, LT6233-10, LT6234, LT6235 (Analog Devices) - 7
Description | 60MHz, Rail-to-Rail Output, 1.9nV/√Hz, 1.2mA Op Amp Family |
Pages / Page | 24 / 7 — elecTrical characTerisTics. TA = 25°C, VS = ±5V, VCM = VOUT = 0V, ENABLE … |
File Format / Size | PDF / 792 Kb |
elecTrical characTerisTics. TA = 25°C, VS = ±5V, VCM = VOUT = 0V, ENABLE = 0V, unless otherwise noted. SYMBOL PARAMETER
LT6233/LT6233-10 LT6234/LT6235
elecTrical characTerisTics TA = 25°C, VS = ±5V, VCM = VOUT = 0V, ENABLE = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage LT6233S6, LT6233S6-10 100 500 µV LT6234S8, LT6235GN 50 350 µV LT6234DD 75 450 µV Input Offset Voltage Match 100 600 µV (Channel-to-Channel) (Note 6) IB Input Bias Current 1.5 3 µA IB Match (Channel-to-Channel) (Note 6) 0.04 0.3 µA IOS Input Offset Current 0.04 0.3 µA Input Noise Voltage 0.1Hz to 10Hz 220 nVP-P en Input Noise Voltage Density f = 10kHz 1.9 3.0 nV/√Hz in Input Noise Current Density, Balanced Source f = 10kHz, RS = 10k 0.43 pA/√Hz Input Noise Current Density, Unbalanced Source f = 10kHz, RS = 10k 0.78 pA/√Hz Input Resistance Common Mode 22 MΩ Differential Mode 25 kΩ CIN Input Capacitance Common Mode 2.1 pF Differential Mode 3.7 pF AVOL Large-Signal Gain VO = ±4.5V, RL = 10k 97 180 V/mV VO = ±4.5V, RL = 1k 28 55 V/mV VCM Input Voltage Range Guaranteed by CMRR –3 4 V CMRR Common Mode Rejection Ratio VCM = –3V to 4V 90 110 dB CMRR Match (Channel-to-Channel) (Note 6) VCM = –3V to 4V 84 120 dB PSRR Power Supply Rejection Ratio VS = ±1.5V to ±5V 90 115 dB PSRR Match (Channel-to-Channel) (Note 6) VS = ±1.5V to ±5V 84 115 dB VOL Output Voltage Swing Low (Note 8) No Load 4 40 mV ISINK = 5mA 75 180 mV ISINK = 15mA 165 320 mV VOH Output Voltage Swing High (Note 8) No Load 5 50 mV ISOURCE = 5mA 85 195 mV ISOURCE = 15mA 220 410 mV ISC Short-Circuit Current ±40 ±55 mA IS Supply Current per Amplifier 1.15 1.4 mA Disabled Supply Current per Amplifier ENABLE = 4.65V 0.2 10 µA IENABLE ENABLE Pin Current ENABLE = 0.3V –35 –85 µA VL ENABLE Pin Input Voltage Low 0.3 V VH ENABLE Pin Input Voltage High 4.65 V Output Leakage Current ENABLE = 4.65V, VO = ±1V 0.2 10 µA tON Turn-On Time ENABLE = 5V to 0V, RL = 1k 900 ns tOFF Turn-Off Time ENABLE = 0V to 5V, RL = 1k 100 µs GBW Gain-Bandwidth Product Frequency = 1MHz 42 60 MHz LT6233-10 260 375 MHz SR Slew Rate AV = –1, RL = 1k, VO = –2V to 2V 12 17 V/µs LT6233-10, AV = –10, RL = 1k, VO = –2V to 2V 115 V/µs FPBW Full-Power Bandwidth VOUT = 3VP-P (Note 9) 1.27 1.8 MHz LT6233-10, HD2 = HD3 ≤ 1% 2.2 MHz tS Settling Time (LT6233, LT6234, LT6235) 0.1%, VSTEP = 2V, AV = –1, RL = 1k 170 ns 623345fc 7 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications Package Description Revision History Typical Applications Related Parts
