Datasheet LT6205, LT6206, LT6207 (Analog Devices) - 5
DescriptionQuad Single Supply 3V, 100MHz Video Op Amps
Pages / Page18 / 5 — ELECTRICAL CHARACTERISTICS. The. denotes specifi cations which apply over …
File Format / SizePDF / 267 Kb
ELECTRICAL CHARACTERISTICS. The. denotes specifi cations which apply over the full specifi ed temperature
ELECTRICAL CHARACTERISTICS The denotes specifi cations which apply over the full specifi ed temperature
LT6205/LT6206/LT6207
denotes specifi cations which apply over the full specifi ed temperature range, –40°C ≤ TA ≤ 125°C, otherwise specifi cations are at TA = 25°C. VS = 3V, 0V; VS = 5V, 0V; VCM = VOUT = 1V, unless otherwise noted. LT6205H SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IOS Input Offset Current l 5 μA Input Noise Voltage 0.1Hz to 10Hz 2 μVP-P en Input Noise Voltage Density f = 10kHz 9 nV/√Hz in Input Noise Current Density f = 10kHz 4 pA/√Hz Input Resistance VCM = 0V to V+ – 2V 1 MΩ Input Capacitance 2 pF CMRR Common Mode Rejection Ratio VCM = 0V to V+ – 2V l 72 dB Input Voltage Range l 0 V+ – 2 V PSRR Power Supply Rejection Ratio VS = 3V to 12V l 62 dB VCM = VOUT = 0.5V Minimum Supply Voltage VCM = 0.5V l 2.7 V AVOL Large-Signal Voltage Gain VS = 5V, V0 = 0.5V to 4.5V, RL = 1k l 25 V/mV VS = 5V, V0 = 1V to 3V, RL = 150Ω l 3.5 V/mV VS = 3V, V0 = 0.5V to 2.5V, RL = 1k l 15 V/mV VOL Output Voltage Swing Low (Note 7) No Load, Input Overdrive = 30mV l 40 mV ISINK = 5mA l 200 mV VS = 5V, ISINK = 25mA l 600 mV VS = 3V, ISINK = 15mA l 400 mV VOH Output Voltage Swing High (Note 7) No Load, Input Overdrive = 30mV l 125 mV ISOURCE = 5mA l 300 mV VS = 5V, ISOURCE = 25mA l 1400 mV VS = 3V, ISOURCE = 15mA l 600 mV ISC Short-Circuit Current VS = 5V, Output Shorted to GND 35 60 mA l 20 mA VS = 3V, Output Shorted to GND 30 50 mA l 15 mA IS Supply Current per Amplifi er 3.75 5 mA l 6.5 mA GBW Gain Bandwidth Product f = 2MHz l 50 MHz SR Slew Rate VS = 5V, AV = 2, RF = RG = 1k 450 V/μs VO = 1V to 4V, Measured from 1.5V to 3.5V Channel Separation f = 10MHz 90 dB FPBW Full Power Bandwidth VOUT = 2VP-P (Note 8) 71 MHz ts Settling Time to 3% VS = 5V, ΔVOUT = 2V, AV = –1, RL = 150Ω 15 ns Settling Time to 1% 25 ns Differential Gain VS = 5V, AV = 2, RL = 150Ω, Output Black Level = 1V 0.05 % Differential Phase VS = 5V, AV = 2, RL = 150Ω, Output Black Level = 1V 0.08 Deg
The
denotes specifi cations which apply over the full specifi ed temperature range, –40°C ≤ TA ≤ 125°C, otherwise specifi cations are at TA = 25°C. VS = ±5V; VCM = VOUT = 0V, unless otherwise noted. LT6205H SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 1.3 4.5 mV l 7 mV Input Offset Voltage Drift (Note 6) l 25 μV/°C 620567fc 5 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION TYPICAL APPLICATION PACKAGE DESCRIPTION REVISION HISTORY TYPICAL APPLICATION RELATED PARTS
