Datasheet LT6220, LT6221, LT6222 (Analog Devices) - 9
Description | Single/Dual/Quad 60MHz, 20V/µs, Low Power, Rail-to-Rail Input and Output Precision Op Amps |
Pages / Page | 22 / 9 — Typical perForMance characTerisTics. VOS Distribution, VCM = 0V. VOS … |
File Format / Size | PDF / 373 Kb |
Typical perForMance characTerisTics. VOS Distribution, VCM = 0V. VOS Distribution, VCM = 5V. (S8, PNP Stage). (SOT5, PNP Stage)
LT6220/LT6221/LT6222
Typical perForMance characTerisTics VOS Distribution, VCM = 0V VOS Distribution, VCM = 0V VOS Distribution, VCM = 5V (S8, PNP Stage) (SOT5, PNP Stage) (S8, NPN Stage)
50 50 50 VS = 5V, 0V VS = 5V, 0V VS = 5V, 0V 45 VCM = 0V 45 VCM = 0V 45 VCM = 5V 40 40 40 35 35 35 30 30 30 25 25 25 20 20 20 15 15 15 PERCENT OF UNITS (%) PERCENT OF UNITS (%) PERCENT OF UNITS (%) 10 10 10 5 5 5 0 0 0 –250 –150 –50 0 50 150 250 –1000 –600 –200 0 200 600 1000 –2000 –1200 –400 0 400 1200 2000 INPUT OFFSET VOLTAGE (µV) INPUT OFFSET VOLTAGE (µV) INPUT OFFSET VOLTAGE (µV) 622012 G01 622012 G02 622012 G03
VOS Distribution, VCM = 5V Offset Voltage (SOT5, NPN Stage) Supply Current vs Supply Voltage vs Input Common Mode Voltage
50 3 700 VS = 5V, 0V VS = 5V, 0V 45 VCM = 5V TYPICAL PART 500 40 35 300 2 TA = –55°C 30 TA = 125°C 100 25 T T A = 25°C A = 25°C 20 –100 TA = 125°C 15 1 PERCENT OF UNITS (%) OFFSET VOLTAGE (µV) –300 10 TA = –55°C –500 5 SUPPLY CURRENT PER AMPLIFIER (mA) 0 0 –700 –3000 –1800 –600 0 600 1800 3000 0 1 2 3 4 5 6 7 8 9 10 11 12 0 1 2 3 4 5 INPUT OFFSET VOLTAGE (µV) TOTAL SUPPLY VOLTAGE (V) INPUT COMMON MODE VOLTAGE (V) 622012 G04 622012 G05 622012 G06
Input Bias Current Input Bias Current Output Saturation Voltage vs Common Mode Voltage vs Temperature vs Load Current (Output Low)
400 0.6 10 VS = 5V, 0V TA = 25°C VS = 5V, 0V VS = 5V, 0V 300 TA = –55°C 0.5 200 0.4 1 100 NPN ACTIVE TA = 125°C V 0 0.3 CM = 5V TA = 125°C –100 0.2 0.1 –200 0.1 PNP ACTIVE –300 V TA = 25°C CM = 1V INPUT BIAS CURRENT (nA) INPUT BIAS CURRENT (µA) 0 0.01 –400 –500 –0.1 OUTPUT SATURATION VOLTAGE (V) TA = –55°C –600 –0.2 0.001 0 1 2 3 4 5 6 –55 –25 5 35 65 95 125 0.01 0.1 1 10 100 COMMON MODE VOLTAGE (V) TEMPERATURE (°C) LOAD CURRENT (mA) 622012 G07 622012 G08 622012 G09 622012fc For more information www.linear.com/LT6220/LT6221/LT6222 9 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
