Datasheet LT1722, LT1723, LT1724 (Analog Devices)
DescriptionQuad 200MHz Low Noise Precision Op Amps
Pages / Page18 / 1 — FEATURES. DESCRIPTION. 3.8nV/√Hz Input Noise Voltage. 3.7mA Supply …
File Format / SizePDF / 306 Kb
FEATURES. DESCRIPTION. 3.8nV/√Hz Input Noise Voltage. 3.7mA Supply Current. 200MHz Gain Bandwidth
Datasheet LT1722, LT1723, LT1724 Analog Devices
LT1722/LT1723/LT1724 Single, Dual, Quad 200MHz Low Noise Precision Op Amps
FEATURES DESCRIPTION
n
The LT®1722/LT1723/LT1724 are single/dual/quad, low n
noise, low power, high speed operational amplifi ers. These n
products feature lower input offset voltage, lower input bias n
Low Total Harmonic Distortion: – 85dBc at 1MHz
current and higher DC gain than devices with comparable n 70V/μs Slew Rate bandwidth. The 200MHz gain bandwidth ensures high n 400μV Maximum Input Offset Voltage open-loop gain at video frequencies. n 300nA Maximum Input Bias Current The low input noise voltage is achieved with reduced n Unity-Gain Stable supply current. The total noise is optimized for a source n Capacitive Load Stable Up to 100pF resistance between 0.8k and 12k. Due to the input bias n 23mA Minimum Output Current current cancellation technique used, the resistance seen n Specifi ed at ±5V and Single 5V by each input does not need to be balanced. n Low Profi le (1mm) SOT-23 (ThinSot™) Package The output drives a 150Ω load to ±3V with ±5V supplies.
On a single 5V supply the output swings from 1.5V to 3.5V with a 500Ω load connected to 2.5V. The amplifi er n Video and RF Amplifi cation is unity-gain stable (C n LOAD ≤ 100pF). ADSL, HDSL II, VDSL Receivers n Active Filters The LT1722/LT1723/LT1724 are manufactured on Linear n Wideband Amplifi ers Technology’s advanced low voltage complementary n Buffers bipolar process. The LT1722 is available in the SO-8 and n Data Acquisition Systems 5-pin SOT-23 packages. The LT1723 is available in the L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks of Linear SO-8 and MS8 packages. The LT1724 is available in the Technology Corporation. ThinSOT is a trademark of Linear Technology Corporation. All other 14-lead SO package. trademarks are the property of their respective owners.
TYPICAL APPLICATION Differential Video Line Driver
C1 5pF R3
Line Driver Mulitburst Video Signal
750Ω R5 2k – R7 +V 62.5Ω OUT 0.5V/DIV 1/2 LT1723 + VIN 125Ω CAT-5 V C2 5pF V IN IN/2 62.5Ω V TWISTED PAIR IN 1V/DIV 75Ω +VOUT LOAD R2 SOURCE 2k R4 2k –VOUT –VOUT 62.5Ω 0.5V/DIV –V LOAD IN/2 – R1 R6 75Ω 62.5Ω 1723 TA02 1723 TA01 1/2 LT1723 + –VIN 172234fb 1
