Datasheet LT1361, LT1362 (Analog Devices) - 3
Description | Dual and Quad 50MHz, 800V/µs Op Amps |
Pages / Page | 12 / 3 — ELECTRICAL CHARACTERISTICS TA = 25. C, VCM = 0V unless otherwise noted. … |
File Format / Size | PDF / 236 Kb |
ELECTRICAL CHARACTERISTICS TA = 25. C, VCM = 0V unless otherwise noted. SYMBOL. PARAMETER. CONDITIONS. VSUPPLY. MIN. TYP. MAX. UNITS
LT1361/LT1362
C, VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
Input Voltage Range + ±15V 12.0 13.4 V ±5V 2.5 3.4 V ±2.5V 0.5 1.1 V Input Voltage Range – ±15V –13.2 –12.0 V ±5V –3.2 –2.5 V ±2.5V –0.9 –0.5 V CMRR Common Mode Rejection Ratio VCM = ±12V ±15V 86 92 dB VCM = ±2.5V ±5V 79 84 dB VCM = ±0.5V ±2.5V 68 74 dB PSRR Power Supply Rejection Ratio VS = ±2.5V to ±15V 93 105 dB AVOL Large-Signal Voltage Gain VOUT = ±12V, RL = 1k ±15V 4.5 9.0 V/mV VOUT = ±10V, RL = 500Ω ±15V 3.0 6.5 V/mV VOUT = ±2.5V, RL = 500Ω ±5V 3.0 6.4 V/mV VOUT = ±2.5V, RL = 150Ω ±5V 1.5 4.2 V/mV VOUT = ±1V, RL = 500Ω ±2.5V 2.5 5.2 V/mV VOUT Output Swing RL = 1k, VIN = ±40mV ±15V 13.5 13.9 ±V RL = 500Ω, VIN = ±40mV ±15V 13.0 13.6 ±V RL = 500Ω, VIN = ±40mV ±5V 3.5 4.0 ±V RL = 150Ω, VIN = ±40mV ±5V 3.2 3.8 ±V RL = 500Ω, VIN = ±40mV ±2.5V 1.3 1.7 ±V IOUT Output Current VOUT = ±13V ±15V 26 34 mA VOUT = ±3.2V ±5V 21 29 mA ISC Short-Circuit Current VOUT = 0V, VIN = ±3V ±15V 40 54 mA SR Slew Rate AV = – 2, (Note 5) ±15V 600 800 V/µs ±5V 250 350 V/µs Full Power Bandwidth 10V Peak, (Note 6) ±15V 12.7 MHz 3V Peak, (Note 6) ±5V 18.6 MHz GBW Gain Bandwidth f = 200kHz ±15V 35 50 MHz ±5V 25 37 MHz ±2.5V 32 MHz tr, tf Rise Time, Fall Time AV = 1, 10%-90%, 0.1V ±15V 3.1 ns ±5V 4.3 ns Overshoot AV = 1, 0.1V ±15V 35 % ±5V 27 % Propagation Delay 50% VIN to 50% VOUT, 0.1V ±15V 5.2 ns ±5V 6.4 ns ts Settling Time 10V Step, 0.1%, AV = –1 ±15V 60 ns 10V Step, 0.01%, AV = –1 ±15V 90 ns 5V Step, 0.1%, AV = –1 ±5V 65 ns Differential Gain f = 3.58MHz, AV = 2, RL = 150Ω ±15V 0.20 % ±5V 0.20 % f = 3.58MHz, AV = 2, RL = 1k ±15V 0.04 % ±5V 0.02 % Differential Phase f = 3.58MHz, AV = 2, RL = 150Ω ±15V 0.40 Deg ±5V 0.30 Deg f = 3.58MHz, AV = 2, RL = 1k ±15V 0.07 Deg ±5V 0.26 Deg RO Output Resistance AV = 1, f = 1MHz ±15V 1.4 Ω Channel Separation VOUT = ±10V, RL = 500Ω ±15V 100 113 dB IS Supply Current Each Amplifier ±15V 4.0 5.0 mA Each Amplifier ±5V 3.8 4.8 mA 3
