Datasheet LT1361, LT1362 (Analog Devices) - 7
DescriptionDual and Quad 50MHz, 800V/µs Op Amps
Pages / Page12 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Output Impedance vs Frequency. Gain …
File Format / SizePDF / 236 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Output Impedance vs Frequency. Gain and Phase vs Frequency. Crosstalk vs Frequency
TYPICAL PERFORMANCE CHARACTERISTICS Output Impedance vs Frequency Gain and Phase vs Frequency Crosstalk vs Frequency
LT1361/LT1362
W U TYPICAL PERFORMANCE CHARACTERISTICS Output Impedance vs Frequency Gain and Phase vs Frequency Crosstalk vs Frequency
100 70 120 – 20 T – 30 A = 25°C 60 PHASE 100 AV = 1 A VS = ±15V PHASE (DEG) V ) V = 100 AV = 10 – 40 IN = 0dBm Ω 10 50 80 GAIN VS = ±15V – 50 40 60 A – 60 V = 1 V 1 30 S = ±5V 40 –70 GAIN (dB) VS = ±5V 20 20 – 80 VS = ±15V CROSSTALK (dB) RL = 1k – 90 OUTPUT IMPEDANCE ( 0.1 10 0 VS = ±5V V T –100 A = 25°C R S = ±15V L = 500Ω T 0 A A = 25°C V = –1 –110 RF = RG = 1k 0.01 –10 –120 10k 100k 1M 10M 100M 10k 100k 1M 10M 100M 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) 1361/1362 G13 1361/1362 G14 1361/1362 G21
Gain Bandwidth and Phase Frequency Response vs Frequency Response vs Margin vs Temperature Supply Voltage (AV = 1) Capacitive Load
80 50 5 12 PHASE MARGIN T V C = 1000pF V 45 A = 25°C S = ±15V S = ± 5V 4 10 A T V = 1 A = 25°C 70 40 3 RL = 1k 8 AV = –1 PHASE MARGIN (DEG) C = 500pF PHASE MARGIN ± 35 2 15V 6 VS = ±15V C = 100pF 60 30 1 4 C = 50pF 25 GAIN BANDWIDTH 0 2 50 VS = ±15V 20 GAIN (dB) –1 0 C = 0 ±5V 15 –2 –2 GAIN BANDWIDTH GAIN BANDWIDTH (MHz) 40 V VOLTAGE MAGNITUDE (dB) S = ± 5V 10 –3 –4 5 –4 –6 ±2.5V 30 0 –5 –8 – 50 –25 0 25 50 75 100 125 100k 1M 10M 100M 1M 10M 100M TEMPERATURE (°C) FREQUENCY (Hz) FREQUENCY (Hz) 1361/1362 G16 1361/1362 G17 1361/1362 G18
Gain Bandwidth and Phase Power Supply Rejection Ratio Common Mode Rejection Ratio Margin vs Supply Voltage vs Frequency vs Frequency
80 50 100 120 VS = ±15V +PSRR V T 48 S = ±15V A = 25°C TA = 25°C TA = 25°C 100 70 46 80 – PSRR PHASE MARGIN PHASE MARGIN (DEG) 44 80 60 42 60 60 40 50 38 40 40 36 GAIN BANDWIDTH (MHz) 20 40 GAIN BANDWIDTH 34 20 POWER SUPPLY REJECTION RATIO (dB) COMMON-MODE REJECTION RATIO (dB) 32 0 0 30 30 100 1k 10k 100k 1M 10M 100M 1k 10k 100k 1M 10M 100M 0 5 10 15 20 FREQUENCY (Hz) FREQUENCY (Hz) SUPPLY VOLTAGE (±V) 1361/1362 G19 1361/1362 G20 1361/1362 G15 7
