Datasheet LT1360 (Analog Devices) - 4
Description | 50MHz, 800V/µs Op Amp |
Pages / Page | 16 / 4 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply … |
File Format / Size | PDF / 229 Kb |
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the temperature range
LT1360
denotes the specifications which apply over the temperature range 0
C
TA
70
C, VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 4) ±15V ● 1.5 mV ±5V ● 1.5 mV ±2.5V ● 1.7 mV Input VOS Drift (Note 7) ±2.5V to ±15V ● 9 12 µV/°C IOS Input Offset Current ±2.5V to ±15V ● 350 nA IB Input Bias Current ±2.5V to ±15V ● 1.5 µA CMRR Common Mode Rejection Ratio VCM = ±12V ±15V ● 84 dB VCM = ±2.5V ±5V ● 77 dB VCM = ±0.5V ±2.5V ● 66 dB PSRR Power Supply Rejection Ratio VS = ±2.5V to ±15V ● 91 dB AVOL Large-Signal Voltage Gain VOUT = ±12V, RL = 1k ±15V ● 3.6 V/mV VOUT = ±10V, RL = 500Ω ±15V ● 2.4 V/mV VOUT = ±2.5V, RL = 500Ω ±5V ● 2.4 V/mV VOUT = ±2.5V, RL = 150Ω ±5V ● 1.0 V/mV VOUT = ±1V, RL = 500Ω ±2.5V ● 2.0 V/mV VOUT Output Swing RL = 1k, VIN = ±40mV ±15V ● 13.4 ±V RL = 500Ω, VIN = ±40mV ±15V ● 12.8 ±V RL = 500Ω, VIN = ±40mV ±5V ● 3.4 ±V RL = 150Ω, VIN = ±40mV ±5V ● 3.1 ±V RL = 500Ω, VIN = ±40mV ±2.5V ● 1.2 ±V IOUT Output Current VOUT = ±12.8V ±15V ● 25 mA VOUT = ±3.1V ±5V ● 20 mA ISC Short-Circuit Current VOUT = 0V, VIN = ±3V ±15V ● 32 mA SR Slew Rate AV = –2, (Note 5) ±15V ● 475 V/µs ±5V ● 185 V/µs IS Supply Current ±15V ● 5.8 mA ±5V ● 5.6 mA 4
