Datasheet LT1226 (Analog Devices) - 2
DescriptionLow Noise Very High Speed Operational Amplifier
Pages / Page8 / 2 — ABSOLUTE. AXI U. R TI GS. PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHAR C. A …
File Format / SizePDF / 221 Kb
ABSOLUTE. AXI U. R TI GS. PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHAR C. A TERISTICS VS =. 15V, TA = 25
ABSOLUTE AXI U R TI GS PACKAGE/ORDER I FOR ATIO ELECTRICAL CHAR C A TERISTICS VS = 15V, TA = 25
LT1226
W W W U U W U ABSOLUTE AXI U A R TI GS PACKAGE/ORDER I FOR ATIO
Total Supply Voltage (V+ to V–) ... 36V ORDER PART Differential Input Voltage ... ±6V TOP VIEW NUMBER Input Voltage ..±VS NULL 1 8 NULL Output Short Circuit Duration (Note 1) .. Indefinite LT1226CN8 –IN 2 7 V+ Operating Temperature Range LT1226CS8 +IN 3 6 OUT LT1226C .. 0°C to 70°C V– 4 5 NC Maximum Junction Temperature S8 PART MARKING N8 PACKAGE S8 PACKAGE Plastic Package .. 150°C 8-LEAD PLASTIC DIP 8-LEAD PLASTIC SOIC 1226 Storage Temperature Range ... – 65°C to 150°C LT1226 PO01 Lead Temperature (Soldering, 10 sec.)... 300°C
15V, TA = 25
C, VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 2) 0.3 1.0 mV IOS Input Offset Current 100 400 nA IB Input Bias Current 4 8 µA en Input Noise Voltage f = 10kHz 2.6 nV/√Hz in Input Noise Current f = 10kHz 1.5 pA/√Hz RIN Input Resistance VCM = ±12V 24 40 MΩ Differential 15 kΩ CIN Input Capacitance 2 pF Input Voltage Range + 12 14 V Input Voltage Range – – 13 – 12 V CMRR Common-Mode Rejection Ratio VCM = ±12V 94 103 dB PSRR Power Supply Rejection Ratio VS = ±5V to ±15V 94 110 dB AVOL Large Signal Voltage Gain VOUT = ±10V, RL = 500Ω 50 150 V/mV VOUT Output Swing RL = 500Ω 12.0 13.3 ±V IOUT Output Current VOUT = ±12V 24 40 mA SR Slew Rate (Note 3) 250 400 V/µs Full Power Bandwidth 10V Peak, (Note 4) 6.4 MHz GBW Gain Bandwidth f = 1MHz 1 GHz tr, tf Rise Time, Fall Time AVCL = + 25,10% to 90%, 0.1V 5.5 ns Overshoot AVCL = +25, 0.1V 35 % Propagation Delay 50% VIN to 50% VOUT 5.5 ns ts Settling Time 10V Step, 0.1%, AV = – 25 100 ns Differential Gain f = 3.58MHz, AV = +25, RL = 150Ω 0.7 % Differential Phase f = 3.58MHz, AV = +25, RL = 150Ω 0.6 Deg RO Output Resistance AVCL = +25, f = 1MHz 3.1 Ω IS Supply Current 7 9 mA 2
