Datasheet LT1187 (Analog Devices) - 6
Description | Low Power Video Difference Amplifier |
Pages / Page | 18 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Bias Current vs. Common Mode … |
File Format / Size | PDF / 596 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Input Bias Current vs. Common Mode Voltage vs. Common Mode Voltage
LT1187
TYPICAL PERFORMANCE CHARACTERISTICS Input Bias Current vs Common Mode Voltage vs Common Mode Voltage Input Bias Current vs Temperature Temperature
3.0 100 V+ VS = 5V –0.5 V+ = 1.8V TO 9V 2.5 0 +IB –1.0 2.0 –1.5 –2.0 1.5 –100 –IB –55°C I 1.0 OS –200 2.0 0.5 25°C 1.5 INPUT BIAS CURRENT (µA) INPUT BIAS CURRENT (nA) V+ = –1.8V TO –9V –300 COMMON MODE RANGE (V) 1.0 0 125°C 0.5 –0.5 –400 V– –5 –4 –3 –2 –1 0 1 2 3 4 5 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 COMMON MODE VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C) 1187 G01 1187 G02 1187 G03
Equivalent Input Noise Voltage vs Equivalent Input Noise Current vs Frequency Frequency Supply Current vs Supply Voltage
600 12 16 V V √Hz) S = 5V S = 5V T √Hz) A = 25°C TA = 25°C 500 RS = 0Ω 10 RS = 100k –55°C 14 400 8 25°C 300 6 12 125°C 200 4 SUPPLY CURRENT (mA) 10 100 2 EQUIVALENT INPUT NOISE VOLTAGE (nV/ 0 EQUIVALENT INPUT NOISE CURRENT (pA/ 0 8 10 100 1k 10k 100k 10 100 1k 10k 100k 0 2 4 6 8 10 FREQUENCY (Hz) FREQUENCY (Hz) SUPPLY VOLTAGE (V) 1187 G04 1187 G05 1187 G06
Shutdown Supply Current vs Temperature Gain Error vs Temperature Open-Loop Gain vs Temperature
6 0 8 V VS = 5V V S = 5V S = 5V VOUT = 2V VO = 3V 5 AV = 10 RL = 1k –0.05 RL = 1k 6 V V) 4 S/D = –VEE + 0.6V VS/D = –VEE + 0.4V 3 –0.10 4 RL = 500Ω VS/D = –VEE + 0.2V 2 GAIN ERROR (%) –0.15 OPEN-LOOP GAIN (kV/ 2 1 SHUTDOWN SUPPLY CURRENT (mA) VS/D = –VEE 0 –0.20 0 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (C) TEMPERATURE (C) 1187 G07 1187 G08 1187 G09 1187fb 6 For more information www.linear.com/LT1187 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information ±5V Electrical Characteristics 5V Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Package Description Revision History Related Parts
