Datasheet LT1126, LT1127 (Analog Devices) - 8
Description | Dual/Quad Decompensated Low Noise, High Speed Precision Op Amps |
Pages / Page | 12 / 8 — TYPICAL APPLICATI. Low Noise, Wideband, Gain = 100 Amplifier with High … |
File Format / Size | PDF / 282 Kb |
TYPICAL APPLICATI. Low Noise, Wideband, Gain = 100 Amplifier with High Input Impedance. PACKAGE DESCRIPTIO. J8 Package
LT1126/LT1127
O U TYPICAL APPLICATI S Low Noise, Wideband, Gain = 100 Amplifier with High Input Impedance
1.1k 120 – 2.4k 7.5k 500Ω 1/4 LT1127 + 1.1k 2.4k – 1/4 OUTPUT LT1127 120 – + 1/4 LT1127 INPUT + 1.1k 2.4k –3dB BANDWIDTH = 910 kHz 120 – GAIN BANDWIDTH PRODUCT = 91.0MHz 1/4 3.2nV/√Hz LT1127 WIDEBAND NOISE = = 1.85nV/√Hz REFERRED TO INPUT √3 + RMS NOISE DC TO FULL BANDWIDTH = 21.2µV REFERRED TO INPUT 1126-7 TA04
U PACKAGE DESCRIPTIO J8 Package 8-Lead CERDIP (Narrow .300 Inch, Hermetic)
(Reference LTC DWG # 05-08-1110) .200 .405 (5.080) (10.287) CORNER LEADS OPTION .005 (4 PLCS) MAX MAX (0.127) .300 BSC MIN .015 – .060 8 7 6 5 (7.62 BSC) (0.381 – 1.524) .023 – .045 (0.584 – 1.143) .025 HALF LEAD .220 – .310 OPTION (0.635) (5.588 – 7.874) RAD TYP .045 – .068 (1.143 – 1.650) .008 – .018 0° – 15° FULL LEAD .045 – .065 .125 1 2 3 (0.203 – 0.457) 4 OPTION (1.143 – 1.651) 3.175 MIN .014 – .026 .100 NOTE: LEAD DIMENSIONS APPLY TO SOLDER DIP/PLATE OR TIN PLATE LEADS (0.360 – 0.660) (2.54) BSC J8 0801
OBSOLETE PACKAGE
11267fa 8
