Datasheet LT1194 (Analog Devices) - 3
DescriptionVideo Difference Amplifier
Pages / Page12 / 3 — ELECTRICAL CHARACTERISTICS. VS =. 5V, VREF = 0V, Null Pins 1 and 8 open …
File Format / SizePDF / 257 Kb
ELECTRICAL CHARACTERISTICS. VS =. 5V, VREF = 0V, Null Pins 1 and 8 open circuit, TA = 25. C, CL. 10pF,. unless otherwise noted
ELECTRICAL CHARACTERISTICS VS = 5V, VREF = 0V, Null Pins 1 and 8 open circuit, TA = 25 C, CL 10pF, unless otherwise noted
LT1194
C, CL
10pF, unless otherwise noted. LT1194M/C SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
Overshoot VO = ±125mV 0 % ts Settling Time 3V Step, 0.1% (Note 7) 200 ns Diff AV Differential Gain RL = 150Ω (Note 8) 0.2 % Diff Ph Differential Phase RL = 150Ω (Note 8) 0.08 DegP-P IS Supply Current 35 43 mA
V
S = 5V, VS = 0V, VREF = 2.5V, Null Pins 1 and 8 open circuit, TA = 25
C, CL
10pF
VOS Input Offset Voltage All Packages 2 8 mV IOS Input Offset Current 0.2 3 µA IB Input Bias Current ±0.5 ±3 µA Input Voltage Range 2 3.5 V CMRR Common Mode Rejection Ratio VCM = 2V to 3.5V 55 70 dB VLIM Output Voltage Limit VI = ±0.5V, VC = 2V (Note 4) ±20 ±120 mV VOUT Output Voltage Swing RL = 100Ω to Ground VOUT High 3.6 3.8 V VOUT Low 0.25 0.4 V SR Slew Rate VO = 1V to 3V 250 V/µs BW Small-Signal Bandwidth 32 MHz IS Supply Current 32 40 mA
The
denotes specifications which apply over the full operating temperature range of – 55
C
TA
125
C. VS =
5V, VREF = 0V, Null Pins 1 and 8 open circuit, unless otherwise noted. LT1194M SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage N8 Package ● 1 9 mV ∆VOS/∆T Input VOS Drift ● 6 mV/°C IOS Input Offset Current ● 0.8 5 µA IB Input Bias Current ● ±1 ±5.5 µA Input Voltage Range ● – 2.5 3.5 V CMRR Common Mode Rejection Ratio VCM = – 2.5V to 3.5V ● 58 80 dB PSRR Power Supply Rejection Ratio VS = ±2.375V to ±5V ● 60 80 dB VLIM Output Voltage Limit VI = ±0.5V, VC = 2V (Note 4) ● ±20 ±150 mV VOUT Output Voltage Swing VS = ±8V, RL = 1k ● 6 6.6 V V = 4V REF RL = 100Ω ● 5.9 6.5 V VS = ±8V, RL = 1k ● – 6.1 – 6.7 V V = –4V REF RL = 100Ω ● – 6 – 6.5 V GE Gain Error VO = ±3V, RL = 1k ● 1 5 % IS Supply Current ● 35 43 mA 3
