Datasheet LT6018 (Analog Devices) - 2
Description33V, Ultralow Noise, Precision Op Amp
Pages / Page22 / 2 — absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion …
absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion http://www.linear.com/product/LT6018#orderinfo
absoluTe MaxiMuM raTings (Note 1) pin conFiguraTion orDer inForMaTion http://www.linear.com/product/LT6018#orderinfo
LT6018
Total Supply Voltage (V+ to V–) ...36V Operating and Specified Temperature Range Input Voltage I-Grade...–40°C to 85°C (+IN, –IN, DGND, EN) ... (V– – 0.3V) to (V+ + 0.3V) H-Grade ... –40°C to 125°C Input Current (+IN, –IN, DGND, EN) ... ±10mA Maximum Junction Temperature .. 150°C Differential Input Current (+IN, –IN) ...±25mA Storage Temperature Range .. –65°C to 150°C Output Current (Note 2) .. 50mARMS S8E Lead Temperature (Soldering, 10 sec) ...300°C Output Short-Circuit Duration ...Thermally Limited
pin conFiguraTion
TOP VIEW TOP VIEW EN 1 12 DGND DGND 1 8 EN 11 NC V+ 3 10 –IN –IN 2 7 V+ 13 9 9 +IN +IN 3 6 OUT OUT 5 8 NC V– 4 5 NC NC 6 7 V– S8E PACKAGE 8-LEAD PLASTIC SO DE12(10) PACKAGE θJA = 36°C/W, θJC = 9°C/W 12(10)-LEAD (4mm × 3mm) PLASTIC DFN EXPOSED PAD (PIN 9) MUST BE CONNECTED TO V– OR FLOATED θ SEE "PIN FUNCTIONS” FOR DETAILS JA = 43°C/W, θJC = 12°C/W EXPOSED PAD (PIN 13) MUST BE CONNECTED TO V– OR FLOATED NC IS NOT INTERNALLY CONNECTED SEE "PIN FUNCTIONS” FOR DETAILS NC IS NOT INTERNALLY CONNECTED PINS 2 AND 4 ARE REMOVED
orDer inForMaTion http://www.linear.com/product/LT6018#orderinfo LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT6018IS8E#PBF LT6018IS8E#TRPBF 6018 8-Lead Plastic S8E Exposed Pad –40°C to 85°C LT6018IDE#PBF LT6018IDE#TRPBF 6018 12-Lead (4mm × 3mm) Plastic DFN –40°C to 85°C LT6018HS8E#PBF LT6018HS8E#TRPBF 6018 8-Lead Plastic S8E Exposed Pad –40°C to 125°C LT6018HDE#PBF LT6018HDE#TRPBF 6018 12-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. 6018fa 2 For more information www.linear.com/LT6018 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Schematic Applications Information Typical Applications Package Description Revision History Typical Applications Related Parts
