Datasheet LT6000, LT6001, LT6002 (Analog Devices) - 8
Description | Single, Dual and Quad, 1.8V, 13µA Precision Rail-to-Rail Op Amps |
Pages / Page | 20 / 8 — TYPICAL PERFOR A CE CHARACTERISTICS. Output Saturation Voltage. Output … |
File Format / Size | PDF / 325 Kb |
TYPICAL PERFOR A CE CHARACTERISTICS. Output Saturation Voltage. Output Short-Circuit Current vs. vs Input Overdrive
LT6000/LT6001/LT6002
W U TYPICAL PERFOR A CE CHARACTERISTICS Output Saturation Voltage Output Short-Circuit Current vs Output Short-Circuit Current vs vs Input Overdrive Total Supply Voltage (Sourcing) Total Supply Voltage (Sinking)
100 14 10 V V S = 5V, 0V CM = 0.5V VCM = 0.5V 90 NO LOAD OUTPUT SHORTED TO V– OUTPUT SHORTED TO V+ 12 TA = 25°C 80 8 10 70 TA = 125°C TA = 125°C 60 6 8 TA = 25°C 50 TA = –55°C 6 40 4 OUTPUT HIGH 30 4 TA = –55°C OUTPUT LOW 20 2 2 OUTPUT SATURATION VOLTAGE (mV) 10 OUTPUT SHORT-CIRCUIT CURRENT (mA) OUTPUT SHORT-CIRCIUT CURRENT (mA) 0 0 0 0 5 10 15 20 25 30 1 2 3 4 5 1 2 3 4 5 INPUT OVERDRIVE (mV) TOTAL SUPPLY VOLTAGE (V) TOTAL SUPPLY VOLTAGE (V) 60012 G10 60012 G11 60012 G12
0.1Hz to 10Hz Output Voltage Noise Noise Voltage Density vs Frequency Input Noise Current vs Frequency
100 1000 VS = ±2.5V VS = 5V, 0V VS = 5V, 0V TA = 25°C √Hz) TA = 25°C 90 √Hz) VCM = 4.5V 80 VCM = 2.5V VCM = 4.5V 100 70 VCM = 2.5V NOISE VOLTAGE (nV/ NOISE VOLTAGE (500nV/DIV) 60 INPUT NOISE CURRENT DENSITY (fA/ 50 10 0 1 2 3 4 5 6 7 8 9 10 1 10 100 1000 1 10 100 1000 TIME (SECONDS) FREQUENCY (Hz) FREQUENCY (Hz) 60012 G13 60012 G14 60012 G15
Open-Loop Gain Open-Loop Gain Open-Loop Gain
60 40 200 VS = 1.8V, 0V VS = 5V, 0V VS = ±2.5V µV) VCM = 0.5V µV) VCM = 2.5V µV) 150 TA = 25°C 40 TA = 25°C TA = 25°C RL = 10k 20 100 20 50 0 R R L = 10k 0 L = 10k 0 RL = 100k –50 –20 R R L = 100k L = 100k –20 –100 –40 –150 CHANGE IN INPUT OFFSET VOLTAGE ( CHANGE IN INPUT OFFSET VOLTAGE ( CHANGE IN INPUT OFFSET VOLTAGE ( –60 –40 – 200 0 0.3 0.6 0.9 1.2 1.5 1.8 0 1 2 3 4 5 –2.5 –2 –1.5 –1 –0.5 0 0.5 1 1.5 2 2.5 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 60012 G16 60012 G17 20012 G18 600012fa 8
