LT1996 WUTYPICAL PERFOR A CE CHARACTERISTICS (Difference Amplifier Configuration)Gain vs FrequencyGain and Phase vs Frequency0.01Hz to 1Hz Voltage Noise 50 40 0 VS = 5V, 0V V PHASE S = 5V, 0V VS = ±15V TA = 25°C T (RIGHT AXIS) A = 25°C –20 TA = 25°C GAIN = 9 40 GAIN = 81 30 –40 MEASURED IN G =117 REFERRED TO OP AMP INPUTS –60 PHASE (deg) 30 GAIN = 27 20 –80 GAIN (LEFT AXIS) –100 GAIN (dB) 20 GAIN = 9 GAIN (dB) 10 –120 –140 10 0 –160 –180 OP AMP VOLTAGE NOISE (100nV/DIV) 0 –10 –200 0.5 1 10 100 500 0.1 1 10 100 400 0 10 20 30 40 50 60 70 80 90 100 FREQUENCY (kHz) FREQUENCY (kHz) TIME (s) 1996 G16 1996 G17 1996 G21 Small Signal Transient Response,Small Signal Transient Response,Small Signal Transient Response,Gain = 9Gain = 27Gain = 81 50mV/DIV 50mV/DIV 50mV/DIV 10µs/DIV 1996 G18 20µs/DIV 1996 G19 50µs/DIV 1996 G20 UUUPI FU CTIO S (Difference Amplifier Configuration)P9 (Pin 1): Noninverting Gain-of-9 input. Connects a 50k resistor to the op amp’s noninverting input. internal resistor to the op amp’s noninverting input. OUT (Pin 6): Output. VOUT = VREF + 9 • (VP1 – VM1) + 27 • P27 (Pin 2): Noninverting Gain-of-27 input. Connects a (VP3 – VM3) + 81 • (VP9 – VM9). (50k/3) internal resistor to the op amp’s noninverting input. VCC (Pin 7): Positive Power Supply. Can be anything from P81 (Pin 3): Noninverting Gain-of-81 input. Connects a 2.7V to 36V above the VEE voltage. (50k/9) internal resistor to the op amp’s noninverting input. M81 (Pin 8): Inverting Gain-of-81 input. Connects a VEE (Pin 4): Negative Power Supply. Can be either ground (50k/9) internal resistor to the op amp’s inverting input. (in single supply applications), or a negative voltage (in M27 (Pin 9): Inverting Gain-of-27 input. Connects a split supply applications). (50k/3) internal resistor to the op amp’s inverting input. REF (Pin 5): Reference Input. Sets the output level when M9 (Pin 10): Inverting Gain-of-9 input. Connects a 50k difference between inputs is zero. Connects a 450k internal internal resistor to the op amp’s inverting input. 1996f 7
