Datasheet LT1991 (Analog Devices) - 9
DescriptionPrecision, 100µA Gain Selectable Amplifier
Pages / Page28 / 9 — TYPICAL PERFORMANCE CHARACTERISTICS. Small Signal Transient Response
File Format / SizePDF / 782 Kb
TYPICAL PERFORMANCE CHARACTERISTICS Small Signal Transient Response
LT1991
TYPICAL PERFORMANCE CHARACTERISTICS Small Signal Transient Response Small Signal Transient Response Small Signal Transient Response
GAIN = 1 GAIN = 3 GAIN = 9 50mV/DIV 50mV/DIV 50mV/DIV 5µs/DIV 1991 G18 5µs/DIV 1991 G19 5µs/DIV 1991 G20
PIN FUNCTIONS (Difference Amplifier Configuration) P1 (Pin 1):
Noninverting Gain-of-1 input. Connects a 450k
OUT (Pin 6):
Output. VOUT = VREF + 1 • (VP1 – VM1) + 3 • internal resistor to the op amp’s noninverting input. (VP3 – VM3) + 9 • (VP9 – VM9).
P3 (Pin 2):
Noninverting Gain-of-3 input. Connects a 150k
VCC (Pin 7):
Positive Power Supply. Can be anything from internal resistor to the op amp’s noninverting input. 2.7V to 36V above the VEE voltage.
P9 (Pin 3):
Noninverting Gain-of-9 input. Connects a 50k
M9 (Pin 8):
Inverting Gain-of-9 input. Connects a 50k internal resistor to the op amp’s noninverting input. internal resistor to the op amp’s inverting input.
VEE (Pin 4):
Negative Power Supply. Can be either ground
M3 (Pin 9):
Inverting Gain-of-3 input. Connects a 150k (in single supply applications), or a negative voltage (in internal resistor to the op amp’s inverting input. split supply applications).
M1 (Pin 10):
Inverting Gain-of-1 input. Connects a 450k
REF (Pin 5):
Reference Input. Sets the output level when internal resistor to the op amp’s inverting input. difference between inputs is zero. Connects a 450k internal
Exposed Pad:
Must be soldered to PCB. resistor to the op amp’s noninverting input.
BLOCK DIAGRAM
M1 M3 M9 VCC OUT 10 9 8 7 6 50k 450k 150k 4pF 450k INM OUT 450k INP LT1991 150k 50k 450k 4pF 1 2 3 4 5 1991 BD P1 P3 P9 VEE REF 1991fh 9 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
