Datasheet LT1218, LT1219 (Analog Devices) - 5
Description | Precision Rail-to-Rail Input and Output Op Amps |
Pages / Page | 16 / 5 — ELECTRICAL CHARACTERISTICS. LT1218L/LT1219L only; 0. C, VS =. 5V, VCM = … |
File Format / Size | PDF / 329 Kb |
ELECTRICAL CHARACTERISTICS. LT1218L/LT1219L only; 0. C, VS =. 5V, VCM = 0V, VO = 0V, VSHDN = 5V, unless otherwise noted. SYMBOL
LT1218/LT1219
ELECTRICAL CHARACTERISTICS LT1218L/LT1219L only; 0
C
TA
70
C, VS =
5V, VCM = 0V, VO = 0V, VSHDN = 5V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = V+ ● 100 250 µV VCM = V– ● 100 250 µV ∆VOS Input Offset Voltage Shift VCM = V – to V + ● 30 90 µV IB Input Bias Current VCM = V+ ● 30 75 nA VCM = V– ● – 75 – 18 nA ∆IB Input Bias Current VCM = V– to V+ ● 50 150 nA IOS Input Offset Current VCM = V + ● 5 25 nA VCM = V– ● 3 25 nA ∆IOS Input Offset Current Shift VCM = V – to V + ● 5 20 nA AVOL Large-Signal Voltage Gain VO = – 4.7V to 4.7V, RL = 10k ● 375 2800 V/mV VO = – 4.5V to 4.5V, RL = 2k ● 275 1300 V/mV CMRR Common Mode Rejection Ratio VCM = V– to V + ● 100 110 dB VOL Output Voltage Swing LOW No Load ● V – + 0.004 V – + 0.014 V ISINK = 0.5mA ● V – + 0.045 V – + 0.100 V ISINK = 5mA ● V – + 0.200 V – + 0.580 V VOH Output Voltage Swing HIGH No Load ● V+ – 0.014 V+ – 0.004 V ISOURCE = 0.5mA ● V+ – 0.150 V+ – 0.075 V ISOURCE = 5mA ● V+ – 0.920 V+ – 0.450 V ISC Short-Circuit Current ● 5 10 mA IS Supply Current ● 400 495 µA Positive Supply Current, SHDN VSHDN = 0V ● 11 54 µA
LT1218L, LT1219L only; – 40
C
TA
85
C, VS =
5V; VCM = 0V, VO = 0V, VSHDN = 5V, unless otherwise noted. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = V+ – 0.15 ● 125 500 µV VCM = V– + 0.15 ● 125 500 µV ∆VOS Input Offset Voltage Shift VCM = V+ – 0.15 to V– + 0.15 ● 35 120 µV IB Input Bias Current VCM = V + – 0.15 ● 80 nA VCM = V– + 0.15 ● – 80 nA ∆IB Input Bias Current VCM = V + – 0.15 to V – + 0.15 ● 160 nA IOS Input Offset Current Shift VCM = V + – 0.15 ● 40 nA VCM = V – + 0.15 ● 40 nA ∆IOS Input Offset Current Shift VCM = V + – 0.15 to V – + 0.15 ● 40 nA AVOL Large-Signal Voltage Gain VO = – 4.7V to 4.7V, RL = 10k ● 300 2000 V/mV VO = – 4.5V to 4.5V, RL = 2k ● 200 600 V/mV CMRR Common Mode Rejection Ratio VCM = V + – 0.15 to V – + 0.15 ● 98 109 dB VOL Output Voltage Swing LOW No Load ● V – + 0.005 V – + 0.015 V ISINK = 0.5mA ● V – + 0.050 V – + 0.105 V ISINK = 2.5mA ● V – + 0.200 V – + 0.620 V VOH Output Voltage Swing HIGH No Load ● V+ – 0.015 V+ – 0.004 V ISOURCE = 0.5mA ● V+ – 0.160 V+ – 0.070 V ISOURCE = 2.5mA ● V+ – 1.000 V+ – 0.400 V ISC Short-Circuit Current ● 5 10 mA IS Supply Current ● 420 525 µA Positive Supply Current, SHDN VSHDN = 0V ● 18 60 µA 5
